Another Idle problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2008, 04:50 PM   #1 (permalink)
Iron Chef IV
View drunken_panda's Photo Gallery
Went up to the hot springs here in SB and now my 04, 4cly wont idle, just sputters out and dies. Sometimes when I keep the revs up at a stop light, it will pulse from 800-1200 RPM. Also when trying to get on to the freeway the engine won't rev beyond about 4,000 RPM, it sounds really deep. I can rev it while stopped. The shifts seem to be a lot softer now than before. CEL is on with P0171 - System too lean. Google suggests MAF, but would that cause the other problems as well?
I was going to try to clean it along with the IAC tonight. Any tips or special tools needed to remove it?
drunken_panda is offline   Reply With Quote
Old 09-22-2008, 05:05 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Does kind of seem like a MAF issue with the idle issue, but doubt thats the problem. Have you had the car serviced recently?
Also check your intake tube for cracks or loose connections.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 09-22-2008, 05:50 PM   #3 (permalink)
Iron Chef IV
New plugs about 30K miles ago, new air filter 1000 miles ago, regular oil changes, basic stuff like that. I should also add that the road to the hot springs is unpaved and washboard. I gave a quick glance, and nothing seems to have come unconnected
Old 09-22-2008, 06:14 PM   #4 (permalink)
JSM1284's Avatar
Check the vacuum lines on the back of the air filter box.
2005 Lexus ES330
Old 09-22-2008, 08:12 PM   #5 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
First clean the TB and MAF.
2006 Camry LE Special Edition
Old 09-23-2008, 10:47 AM   #6 (permalink)
Iron Chef IV
OK, so it turns out the resonator aft of the airbox had come off and was just sitting there. In the dark it looked connected but it was completely disconnected. Reinstalled it and it fixed all my problems, even the idle problem I had with the AC. Im guessing it was always loose which caused the problem with the AC, which started about a month ago. Then the fast turns and bumpy roads this weekend finally knocked it off.
But now comes the question on the damage done. I was driving around for a month with a small hole after the air filter and a day in very dusty environment with a large hole sucking in dust. This road was so dusty that now when I opened the fuel filler door dust comes pouring out.
Old 09-25-2008, 09:39 AM   #7 (permalink)
Iron Chef IV
bump. Dust + Engine can't be good.... right?
