Scored rotors? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2008, 03:04 AM   #1 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
Scored rotors?
Is it normal for brake rotors to become scored or wavy when the pads are not close to being worn out?
I was looking at the rotors and noticed my rotors are scored. I kind of expected them to be smooth, but instead it has a wavy pattern when I ran my fingernail on the rotor radially outwards.
2007 Camry 2.4L 5M
Old 09-23-2008, 06:56 AM   #2 (permalink)
Maven
gdanaher's Avatar
Gameroom cash: $352460
View gdanaher's Photo Gallery
Over time this is going to happen. It should take many miles of use to see this but as the pad wears down the steel you will develop ridges on the disk and lips on the inner and outer edges of the wear surface. If it becomes very pronounced you will need to have the rotors turned when you replace the pads, but with moderate wear some guys will just replace the pads and let the new ones wear in and seat to the disk.
gdanaher is offline   Reply With Quote
Old 09-23-2008, 09:26 AM   #3 (permalink)
480 HP 2.4L = lying ricer
TRD VVTi's Avatar
View TRD VVTi's Photo Gallery
+1
This is usually caused by small rocks, dirt, dust, or other debris. It's normal and common. It actually increases the friction surface area. The only real draw back is when new pads are installed without machining/resurfacing the rotors there will be less contact until the pads seat to the rotor.
2006 Camry LE Special Edition
Old 09-23-2008, 09:39 AM   #4 (permalink)
just a nobody
Post a picture so everyone can see what you are referring to.
N.E.O.
Old 09-23-2008, 02:08 PM   #5 (permalink)
Maven
gdanaher's Avatar
N.E.O.
Better, just go out to the parking lot and start looking at brake rotors. They all do this over time but at 25k miles/40k km, it should be obvious to any eye or well experienced finger tip.
Old 09-23-2008, 02:28 PM   #6 (permalink)
just a nobody
True, but aren't we more interested in how his rotors looks like than what we think they may look like?
N.E.O.
