Clean Gen 6 Garmin nav mount - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-01-2008, 08:52 PM   #1 (permalink)
View captainmike454's Photo Gallery
Gen6 Clean Gen 6 Garmin nav mount
After much messing around trying to mount the Garmin Nuvi nav unit I found this vent mount at best buy for $10 and ran the power cord from the lighter plug in the storage compartment under the ac controles and ran the wire behind the radio through the dash vent.
captainmike454 is offline   Reply With Quote
Old 10-01-2008, 09:07 PM   #2 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
looks better than a suction cup on your windshield.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
Old 10-01-2008, 09:12 PM   #3 (permalink)
LOV
268 HP OWNER
LOV's Avatar
View LOV's Photo Gallery
yep, looks better.
2007 Camry SE V6 , MGM
LOV is offline   Reply With Quote
Old 10-01-2008, 09:27 PM   #4 (permalink)
Loving the camry =)
View skyxliner's Photo Gallery
wow i really like this but isnt' it risky when the cable falls backwards inside....
and how did u power it on?
skyxliner is offline   Reply With Quote
Old 10-01-2008, 09:32 PM   #5 (permalink)
Gameroom cash: $201860
View CamrySExxx's Photo Gallery
yea it would be pretty brutal getting the power cable when it falls back! other than that it looks good.
I usually just use my suction cup and stick it on the screen of the audio deck.
CamrySExxx is offline   Reply With Quote
Old 10-01-2008, 09:40 PM   #6 (permalink)
Gen6 my reply
use the crutchfield radio removal instructions that can be found on this site.
The vent just pulls out and the wire wraps around the ductwork with out being pinched too hard and is held in place and can not slip back into the vent.
The wire runs from the lighter plug behind the flip up door then up behind the radio.
I tried the suction cup on the window it was too far away and the wire running across the dash sucked.
It's easy to hide the nav when parked to keep some jackass from ripping it off.
There is an extra mount in the package that I put on my iphone
Old 10-01-2008, 10:41 PM   #7 (permalink)
Gorky_Park's Avatar
View Gorky_Park's Photo Gallery
You are now blocking the air coming out of the vent...in summer florida heat that is a suicide
2007 SE i4
Gorky_Park is offline   Reply With Quote
Old 10-01-2008, 10:55 PM   #8 (permalink)
geoff5093's Avatar
View geoff5093's Photo Gallery
That looks great! I wish I thought of doing that, lol.
geoff5093 is offline   Reply With Quote
Old 10-01-2008, 11:27 PM   #9 (permalink)
boo.hoo.hoo.
desentrix's Avatar
iTrader Score: 6 reviews
View desentrix's Photo Gallery
Only problem with that solution that I can think of: Condensation will build up on the base of the AC vent, causing it to crack.
Main reason I know:
I had one of those auto Glade air fresheners that clip onto the AC vent. After a month, the moisture under it started making the plastic crack.
My friend had this ghetto spinning thing that clipped onto the vent / same thing happened to his truck.
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
Old 10-01-2008, 11:43 PM   #10 (permalink)
phuangk's Avatar
View phuangk's Photo Gallery
Canada
+1
that's why i stop using those kinda things to put my cell phone.
and AC will cause the moisture inside the electronic devices
2008 Camry SE 4cyl
phuangk is offline   Reply With Quote
Old 10-02-2008, 01:23 AM   #11 (permalink)
Here and there...
Gameroom cash: $153229
View lammydi's Photo Gallery
+1 I stick it on the same screen of the audio/radio text screen.
Old 10-02-2008, 02:22 AM   #12 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
i stick mine in the lower middle windshield. It doesn't obstruct much at all. My garmin's so sexy, all over my chest.
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 10-02-2008, 02:52 AM   #13 (permalink)
boo.hoo.hoo.
desentrix's Avatar
Is it hard coming up with 'so sexy' lines?
I swear, you're so sexy, the English language was created for you.
Old 10-02-2008, 07:34 AM   #14 (permalink)
Gen6 my reply
After being in the airconditioning business for over 25 years I know that the cold air comeing out of the vent is dry and the unit gets less heat than up on the dash in the sun.
I am not worried about the plastic cracking because plastic has been used for AC vents in cars and houses since the early 1970's
When and if the unit fails a couple of years from now it will be outdated by then anyway but for now it is at a good height so I do not have to look down from the road and the touch screen is within reach unlike when I was useing the suctioncup mount on the windshield.
M
Old 10-02-2008, 09:55 AM   #15 (permalink)
Gameroom cash: $287705
View lucky777's Photo Gallery
Get one of these http://www.amazon.com/Bracketron-UFM.../dp/B000U5TUWE
lucky777 is offline   Reply With Quote
