I know its a big stretch considering I'm referring to the Australian Aurion which you guys dont have. But someone may know or have advice...
Just wondering, with the similarities between alot of the Lexus & Toyota range.....does anyone, by ANY chance know if the Lexus LS 460 is similar to the Aurion??
In particular the rear bumper & bootlid. Looking at the pictures they look fairly close but in real life it could be a different story.
My main reason....I really want quad exhausts, but the cut-out on the Aurion is just on 5" wide, so I'd only be able to fit 2x 2" tips in there with a bit of room between and at the sides so the bumper doesn't melt...a pretty tight squeeze & thats not even taking into account them being double-walled tips so the overall tip size would be 2.5".
If the Lexus bumper lines up correctly (somehow doubt) then I'd get a scratched or used one from ImportMonster, get a lip where the tips will fit, get it resprayed and whosyourdaddy. At worst (and cheapest) I would order the lip, remove the Sportivo one & put that one on instead. The lip in the picture below looks like it will fit dual 2.5" tips easy.
Some pics of what I want it too look like & the rear end of the LS460....
My other reason...Dont like the Sportivo spoiler, not a huge fan of the duck tail from Ebay...and came across this one, looks pretty good but I dont know if the bootlids are the same.
Pic...
........... And another reason. I realise that because they have different headlights, bonnet & grill - a front bumper won't fit. But if the width etc. are similar then I was thinking of getting a spare Aurion bumper, cutting it half way between the bottom of the grill & the lower grill. Then buying the LS460 bumper with a lip and cutting in the same spot...do some plastic surgery and make it all smooth...
Example pic - yes I know the colours dont match, doesn't blend - its just a quickie to see. On the upside - the line where the fender meets the front bumper was the same & the wheel arch matches including the flat edge.
Obviously anything is possible with customising, but I dont have $$$$$$ to throw at it so the less I spend the better. The front will cost a bit to do, I understand that.
