hi guys. i know somebody will tell me please use the damn search section. but i cant get a direct answer on my questions.
ok i already installed the lamp it self. the covers etc. the thing is i dont know were to wire them to. it came with an independent switch that i think goes on the socket below the coin tray..
I put the switch and relay in a baggie and taped it up.
Ghettotastic. Seriously, WTF? A baggie? The relay is most likely a Bosch model designed for external mounting, and you don't need the switch if you're going to run them off your lowbeams.
I live on a boat 52 feet long not near the ghetto.
While the relay may be designed to be weatherproof it is not a Bosch but a lower quality unit the switch is definately not waterproof and there are multiple wires going to it.
I could cut up the harness and redesign the circut I was not sure if later I would run the harness through the firewall and use the switch.
i got the glass back!.. hey should i just wire them with the low beams?
nope. get a different switch and run it independently. Because there will be times when u want to turn on ur fogs without lowbeams. btw, get a different switch. that switch cracks easily with heat. Give it about a week before it starts deteriorating.
__________________ Do you need car parts? AdvanceSpeedShop I Am Parting Out: click! Questions about your own stupidity?: PM NJERALD
do you have a pic of your switch?
What is it about...Stance? Flushness? Stretch? or Pokin Out?
ha shoulda txted me or whatever i would of have helped u and showed u what i did...
1stly i had the fogs tapped into the low beams so whenever the lowbeams are on, the fogs are on, simple procedure, soldering involved (for good secure support)
2ndly, after itching to make things OEM, went out and bought the XLE/SE headlight stalk with fog switch, bought the fog relay, installed everything myself and BAM, good as new, a LOT brighter than the 1st procedure and i get to use the factory fog harness' that came preinstalled w/ my car, was very pleased
__________________ Black 2007 Camry LE V6 Current Mods: LED swap, OEM fog lights - 2500K Nokya, 8000K TSX HID retrofits, TRD drop-in air filter, TRD drop, dual Magnaflow Race Series 14851, Sportmax 962 18x8.5 w/ Nankang NSII 225/45/18
