Originally Posted by Camralon2343
disconnect your neg battery terminal and leave it that way for a good 20 mins. When you connect it again, let it idle in gear. And it should relearn it within a few mins
just to add to this, while letting it idle in gear, it is possible for it to stall out. dont worry, just start it up again and let it idle in gear. If it continues to do so, your butterfly valve on the throttle body may be dirty. Clean it up with some carb cleaner.
Also, learn to do a search. As put by our resident jerk, this topic has been discussed quite a few times. Search is your friend.
