HELP! HID Installation Problems
Hey guys,
I bought a HID kit from xenondepot and installed it yesterday. I followed the instructions posted here to remove the bumper and fix the squirrel spotters. Unfortunately, I'm having 2 problems:
1) I used aluminized HVAC duct tape to cover the spotters. Then I pushed the metal flap over (down), but when I did this, I saw a gap at the top. I guess this is why you need to use JB Weld. So instead of starting the procedure over again (I wasn't sure how I was going to bend the flap back), I used JB Weld on a brush and used a few blobs to cover the gaps. Unfortunately, after finishing up last night, I saw that the spotters were not completely covered. There's some light that gets through at the top. It's not that bad, but what can I do to fix it? Before I put them back in, I checked for gaps and I didn't see anything.
2) After putting the bumper back on, it's not completely lined up on the bottom. I can't line up the holes on the bottom splashguard. The other problem is that I don't know which screws/bolts go where :\ Would someone with an SE or with this splashguard mind taking some pictures so I can figure out how to put it back together?
Thanks!
-G
