Courtesy/Door Light LED Swap Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2008, 05:23 PM   #1 (permalink)
The O-Sho
Omer's Avatar
View Omer's Photo Gallery
Question Courtesy/Door Light LED Swap Question
So I finally got to doing my LED swap with interior lights. I got the map, dome, and license plate LEDs done.
Only problem I came upon was on the door/courtesy lights. I opened it up but the bulb seems to be in a housing and I can't reach and pull it out to change it. Can you remove the housing that's protecting it? I tried fiddling with it but didn't want to pull too hard in fear that it might break.
Here's a couple pics:
http://www.cardomain.com/ride/2456437
2007 Camry LE (Magnetic Gray Metallic)
Mods: 6000K Apexcone HID Kit, Interior Footwell LEDs, Chrome Grille Accents, Kydo 9005 Hyper White High Beams
Omer is offline   Reply With Quote
Old 10-18-2008, 05:35 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
http://www.trademotion.com/partlocat...layCatalogid=0
It is an assembly but I could take it apart and install an LED bulb.....if I cared.
Old 10-18-2008, 06:23 PM   #3 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
yes you can take it apart. i forget how to get it but just play around with it, you'll probably get it
CamrySExxx is offline   Reply With Quote
Old 10-18-2008, 07:24 PM   #4 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $477210
iTrader Score: 12 reviews
View bandit's Photo Gallery
Originally Posted by Omer View Post
Play around with there. Where you have your fingers, you have to lift it up. Its held in place like a latch/hook.
CarDomain
Old 10-18-2008, 07:30 PM   #5 (permalink)
2007 Toyota Camry SEI4
evablazinballa's Avatar
View evablazinballa's Photo Gallery
the plastic casing part lifts off and youve got to unhook it be careful not to break the plastic
evablazinballa is offline   Reply With Quote
Old 10-18-2008, 09:21 PM   #6 (permalink)
Loving the camry =)
View skyxliner's Photo Gallery
looks like i'm passing on the courtesy lights haha, too complicated.
skyxliner is offline   Reply With Quote
Old 10-18-2008, 09:27 PM   #7 (permalink)
The O-Sho
Omer's Avatar
Do you have to squeeze anything to release it? Or just pull it off?
Old 10-18-2008, 09:34 PM   #8 (permalink)
Registered User
View scjrod's Photo Gallery
You have to push in one of the sides of the top part because there is a clip holding the top part down to the bulb holder part. You can't just pull it out without releasing the clip that is holding it down underneath.
scjrod is offline   Reply With Quote
Old 10-18-2008, 09:45 PM   #9 (permalink)
must.resist.modding
bandit's Avatar
Its not that hard.
If the weather is good outside, I'll go take a look at it again and see if I can give a better instruction on it. I'll see if I can do a video while I'm holding the camera and takeing it apart.
CarDomain
Old 10-18-2008, 09:48 PM   #10 (permalink)
^ beat ya to it :P ill be uploading it to youtube... not sure how long it will take to verify tho..
Old 10-18-2008, 09:54 PM   #11 (permalink)
http://www.youtube.com/watch?v=RHvnUPO52E8
There's the link but i just uploaded it so it might take a bit to process
Old 10-18-2008, 10:14 PM   #12 (permalink)
must.resist.modding
bandit's Avatar
HAHAHA Thanks.
CarDomain
Old 10-18-2008, 10:47 PM   #13 (permalink)
^ haha had to give myself a reason to take a break from my physics assignment :P
Old 10-19-2008, 12:32 AM   #14 (permalink)
The O-Sho
Omer's Avatar
Haha, thanks so much, both of you.
You guys are great here, really appreciate it.
Great video CamrySExxx, couldn't have asked for more.
Old 03-02-2009, 07:43 PM   #15 (permalink)
Sean89's Avatar
View Sean89's Photo Gallery
How can I take this light out? Just go at it with a flat edge knife and pry it open?
Sean89 is offline   Reply With Quote
