For those who have had Katzkin in the past: - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-30-2008, 11:18 PM   #1 (permalink)
boo.hoo.hoo.
desentrix's Avatar
iTrader Score: 6 reviews
View desentrix's Photo Gallery
Is there a place or site where I can get the hog rings I need to install it myself? Also, which size will I need?
I found this site: to buy the pliers.
Finally, when I disconnect 1 of the battery terminals, will nothing happen after I remove the front-driver/passenger seats?-- I don't want the air bags in the seats to explode or anything on me..
2007 Magnetic Gray Camry LE V6:
Lit door sills, F/R cathode, trunk cathode, K&N SRI, IS250 chromes, LED tails/ bulb swaps, Katzkin leather
desentrix is offline   Reply With Quote
Old 10-31-2008, 12:36 AM   #2 (permalink)
View toyomoho's Photo Gallery
Can't help on the rings, etc.
Leave the battery disconnected for at least 90 seconds before your start disconnecting any harness plugs to the seat.
If the the above is done, the airbag system is off. When removing any airbag electrical plugs don't apply any power to the plug. The airbag has an electrical squib inside it.
Only reconnect the battery and turn on the ign key after you have reconnected all the airbag electrical plugs. If the ign key is on the system will trigger an error code and not work, this even after the airbags are reconnected. The system would then need to be reset.
Old 10-31-2008, 01:01 AM   #3 (permalink)
boo.hoo.hoo.
desentrix's Avatar
Thanks for the info. Makes me feel much more comfortable doing it myself now.
Almost makes me want to do a detailed DIY from a noob's perspective.
Old 10-31-2008, 07:54 AM   #4 (permalink)
Gameroom cash: $175200
View Zackb911's Photo Gallery
I didnt disconnect the battery when I did mine but I'm sure it's a good thing to do for "extra" caution. Hog Rings and pliers can usually be had at a Marine Supply store (boat upholstery, lobster traps, etc). One of the biggest things is take your time and smack/stretch the leather as you go along.
I found a couple little write-ups via google when I was planning mine and they gave me the basics. For the most part you can just figure it out as you go along, just give yourself plenty of time.
If you can't find the hog rings and pliers locally, I can sell/ship you mine (I have way more rings than you'll need) $25 shipped.
Good luck and any questions just ask.
Zack
p.s. I would start with the back ones to get the feel of it so that you'll have it down for the fronts and theyll look nicer. Also when Hog-Ringing them dont do it too tight or else it will look "pulled" to that one spot.
Zackb911 is offline   Reply With Quote
Old 10-31-2008, 09:41 AM   #5 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
please do a write up and pics, I plan on doing this over the winter
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 11-09-2008, 09:00 AM   #6 (permalink)
LIFER
CDUFF777's Avatar
View CDUFF777's Photo Gallery
Man Those Seat Covers Look Like Crap, Expecially If That Is The Set You Bought On Ebay desentrix
1 JDM FROM HERE IN JAPAN
CDUFF777 is offline   Reply With Quote
Old 11-09-2008, 10:43 AM   #7 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
...I do not know about the e-bay Katzkin, but the Katzkin I used are great, much better than my OEM leather in my Camry.
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 11-09-2008, 01:23 PM   #8 (permalink)
boo.hoo.hoo.
desentrix's Avatar
If you goto Katzkin.com => 'products' => 'creative packages-flash' => toyota camry- tuscany edition
You will see what the seat will look like on the right; minus the tuscany stitching.
Old 11-21-2010, 10:46 PM   #9 (permalink)
View coolbeans's Photo Gallery
Anyone have an SE with the katzkin leather installed??? Pics plz if you do...
coolbeans is offline   Reply With Quote
Old 11-21-2010, 10:59 PM   #10 (permalink)
DJV
DJ V, NJ's Underground DJ
View DJV's Photo Gallery
Yeah I second that, would love to see the katzkin pics. Did you install it yourself or did you go somewhere to have install? If you did yourself, how hard was it and how long did it take? If you went somewhere, how much did it cost? Thanks! How much were your seats in general?
09 Camry LE V6 Black
DJV is offline   Reply With Quote
Old 11-22-2010, 10:15 AM   #11 (permalink)
Katzkin aftermarket two-tone leather installed
Old 11-22-2010, 02:14 PM   #12 (permalink)
Originally Posted by Zackb911 View Post
i searched and saw this thread already, but obviously it is not the SE kit. If anyone has the Katzkin leather for the SE model , please share!! Thanks
Old 11-22-2010, 03:20 PM   #13 (permalink)
Take it easy... :-)
Tobeit's Avatar
?? what do you expect to be different? it will fit the SE seats just it does fit the none SE seats, they are custom made for each....but same material choices, stitching choices, 2 color option etc...
