Installing a sub into a Gen 5 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2008, 02:37 AM   #1 (permalink)
View deadfly's Photo Gallery
Gen5 Installing a sub into a Gen 5
Hi,
I am trying to put a sub into my camry. But I can't seem to find any possible way to get the power cable from the battery through the firewall into the cabin.
Anyone done this and can shed some light?
thanks!
deadfly is offline   Reply With Quote
Old 11-02-2008, 11:13 AM   #2 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $283505
View MrSo0h0o's Photo Gallery
Originally Posted by deadfly View Post
Hi,
thanks!
I noticed you are from down under, so are you right hand drive? If so, i dont know if the layout is different, but in my left hand drive, i went through where the driving shaft comes into the cabin. If you open your hood and slide underneath the steering column, you can remove the rubber grommet and find your way into the engine bay. Once there, you should be able to locate it. Good luck!
MrSo0h0o is offline   Reply With Quote
Old 11-02-2008, 02:25 PM   #3 (permalink)
LoudCamry's Avatar
Gameroom cash: $181827
View LoudCamry's Photo Gallery
you can also wire your power wire paralle through the hood release cable, it will work with 4 awg wire, anything bigger you will need to make the hold bigger
LoudCamry is online now   Reply With Quote
Old 11-03-2008, 10:04 PM   #4 (permalink)
View Aceventura9586's Photo Gallery
There's another spot for left side drive vehicles. I'm assuming it will be the same for right side except flipped. There's a rubber grommet that has two little rubber parts that are about 1.5 to 2" long. You can cut the tip off the rubber "nipple" and feed the cable through there. which is what I did. I'll take a pic tomorrow to clarify.
Aceventura9586 is offline   Reply With Quote
Old 11-03-2008, 11:23 PM   #5 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $133432
View Yazovets's Photo Gallery
Honestly, I don't see why manufacturers don't pre-drill a nice 2 inch hole from the factory to save all of modders the trouble.
I mean, of course there's a high likelihood of someone adding a sub when all you provide is 6 x 9 speakers. Or maybe wiring for a foglight switch, etc.
Is it really that big a deal for Toyota to drill us a nice little hole through there?
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is online now   Reply With Quote
Old 11-15-2008, 12:14 AM   #6 (permalink)
Thanks for your suggestions!
Old 11-15-2008, 06:52 PM   #7 (permalink)
Did you ever find that rubber gasket I was talking about?
Old 11-17-2008, 02:53 AM   #8 (permalink)
I did but, on the Australian built models it seems to go straight through to the passenger airbag. sigh
Old 01-16-2009, 01:55 PM   #9 (permalink)
View odagled2005's Photo Gallery
i know this is old but... Aceventura do you have that pic?
odagled2005 is offline   Reply With Quote
