I give up! Engine is junk - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-04-2008, 01:33 PM   #16 (permalink)
SHIFTY23's Avatar
View SHIFTY23's Photo Gallery
WARPEDROTOR,
All the ones I have seen have been over 90,000 miles. And to throw out a percent is hard but I would say maybe 5 percent of the 4cyl engines of 02/03/04 have this problem that have come into our dealership. I can't remember the customers names to get vin's to see where they were built.
SHIFTY23 is offline   Reply With Quote
Old 11-04-2008, 05:58 PM   #17 (permalink)
View warpedrotor's Photo Gallery
Thanks for the info. I have about 60 K miles, I want to keep this car almost for ever, my last one was 21 years old with 200 K miles, still running ok but everything was rotting and breaking just from age.. At 5% the odds aren't too bad, I guess if it happens to me, I should just suck it down and do the work myself, pull the block and get a machine shop to fix the holes. I've done similar work in the past, the car looks easy to work on.
warpedrotor is offline   Reply With Quote
Old 12-04-2008, 07:52 AM   #18 (permalink)
View briandownunda's Photo Gallery
I am curious if you've solved this problem.....if so, did you take the motor to a machine shop or do the work yourself ? Where did you get the helicoils/special tools to do the job ?
I have a 2002 with 140k miles & it has a blown head gasket......I am guessing it is the same problem, but haven't attempted to pull the head yet.
Thanks,
Brian
briandownunda is offline   Reply With Quote
Old 12-04-2008, 08:30 AM   #19 (permalink)
View GeorgiaHybrid's Photo Gallery
Brian,
Look for additional posts by the original poster. He fixed the engine using a different type of insert that seems to be a VERY good fix for the problem. He is completely satisfied with the repair and gave us a blow by blow on the procedure and the cost.
GeorgiaHybrid is offline   Reply With Quote
Old 12-04-2008, 02:13 PM   #20 (permalink)
View toyomoho's Photo Gallery
Might look at TimeSert thread inserts.
http://www.timesert.com/html/toyota.html
Old 12-05-2008, 12:34 PM   #21 (permalink)
FLIP'N THE G-5 WHIP
RICO8458's Avatar
View RICO8458's Photo Gallery
drop a new engine in there, manual 5 speed. mod it.
Got the 50 on my jock cause my G-5 is so Hot...
2005=5.5 2AZ-FE, 2.4L DOHC 16-Value VVT-i, 4CYL, 160hp
RICO8458 is offline   Reply With Quote
