My 2008 LE V6 shakes when stoped in drive.It only has 10K miles.You could expect it at 100K not just 10K .I wonder what`s next.
let me see if i can help.. it shakes when you hit the breaks on drive? or if you have the gear on drive with your foot on the brake?
if it its shaking when you hit the brakes while driving its your break rotors.. the later i dont know what it is.. either its an O2 sensor telling your ECU it has enough air therefore less idle that makes your car shake..
What is it about...Stance? Flushness? Stretch? or Pokin Out?
I am avutally having the same problem. WHen i took it to the dealer, they took it for test and told me that the problem did not resurface. But as soon as i got in and got tio a red light, the car started to shake again. I had my oil changed, and I am running withthe K&N air filter, but still it does this.
The only differnce is that I have a I4 2007 LE model....
The 09' V6 has an Active Control front engine mount which would help dampen some of the engine vibration. The I4s don't have this type of mount, so it may be a different concern.
Nope on mine the A/C is not running, and when it is the shaking is more noticeable..
@Pricess - So if I disconnect the battery, it may help to correct the problem? And i assume i am only disconnecting the positive terminal? And would you say 5 mins would be suffiient time to allow the camry to relearn?
see.. i have a SIMILAR problem..
my steering wheel shakes a bit when i'm
going a bit fast and i brake too fast/hard.
i've learned how to control it by not braking
so hard or so fast but, whever i'm in a hurry
and i do brake a bit hard/fast it goes get annoying.
can anyone tell me why my CAM does this?
