For those of you who don't have access to a manual I was able to get some info on another site. I'm still in the process and will let you know exactly what wires when done.
Another question:
Since the new 2009 Camry's seem to have the AM-FM antenna built into the rear window does this have something to do with the second smaller round antenna connector. On the back of the stock radio there are (2) antenna plugs, one is the normal size and directly above it is another smaller plug. Does anyone know what this plug is for? I thought perhaps it was power to an antenna amplifier for the back window. There appears to be Fujitsu electronics (small metal boxes wired to the window ) in the rear pillars to the right and left of the rear window. Changing the stock radio to an aftermarket one it appears without this connection the AM-FM reception is rather poor.
Does the back winder antenna require some sort of connection to the radio?
Battery
BLACK
IGNITION SWITCH HARNESS
Ignition 1
YELLOW
Starter 1
BLUE
All Door Trigger
BROWN
AT VEHICLE FUSEBOX
Domelight Super
BROWN
AT VEHICLE FUSEBOX
LF Latch
BLUE
AT BECU MODULE IN VEHICLE FUSEBOX
RF Latch
YELLOW
LR Latch
LIGHT GREEN
AT VEHICLE FUSE BOX
RR Latch
GRAY
Trunk Trigger
WHITE
Hood Trigger
RED
AT VEHICLE HOOD PIN SWITCH
Alarm Disarm
BLUE
INGITION SWITCH HARNESS (KEY IN SENSE WIRE)
Parking Lights
BLACK
Battery
BLACK
Ignition 1
YELLOW
Ignition 2
PINK
Accessory 1
WHITE
Starter 1
BLUE
Starter 2
GRAY
Anti-Theft Type
UNIVERSAL IMMOBILIZER
Anti-Theft Descript
THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
Key Sense
BLUE
Tachometer
BLACK
(AC)
AT DATALINK CONNECTOR UNDER DRIVER DASH
Speed Sense
VIOLET
(AC)
RADIO HARNESS
Parking Lights
BLACK
Brake Lights
WHITE
AT SWITCH ABOVE BRAKE PEDAL
Reverse Lights
RED
IN HARNESS IN DRIVER KICKPANEL
Horn
WHITE
AT VEHICLE FUSE BOX
