02 Camry Harsh Shift into Drive When Cold - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-09-2008, 10:33 PM   #1 (permalink)
View Rpov's Photo Gallery
02 Camry V6 with 47,000 mi. clunks in drive when cold. Yet smooth shift into reverse when cold. When car warms up shift into drive becomes smooth. Also when driving cold engine shifts at 3,000 rpm under very mild acceleration. Any solutions?
Rpov is offline   Reply With Quote
Old 11-09-2008, 10:43 PM   #2 (permalink)
Do not buy from
View Zviator's Photo Gallery
Let it idle longer before u drive, soft on gas until the engine and tranny warm up.
I have the common issue and i dont think it's really a problem.
Zviator is offline   Reply With Quote
Old 11-09-2008, 10:45 PM   #3 (permalink)
Goes Against The Grain
Punks_Not_Dead5's Avatar
Gameroom cash: $1077958
iTrader Score: 7 reviews
get the EGR valve checked....mine was doing this..and it was the EGR valve.
2002 Camry SE V6 "Snow White"
Old 11-09-2008, 11:00 PM   #4 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
x2... let the car warm up before you drive away. the car idles at a higher RPM when cold to get the car up to running temp. quicker. also, if you have been doing this all of your 47k miles, i would get your engine mounts checked, as they may be broken, hence the clunking sound.
MrSo0h0o is offline   Reply With Quote
Old 11-10-2008, 12:12 AM   #5 (permalink)
just a nobody
Have you try resetting the memory to see if that helps?
N.E.O.
Old 11-10-2008, 08:45 AM   #6 (permalink)
self-proclaimed geenyus
jermyjerm's Avatar
View jermyjerm's Photo Gallery
Gen5 normal
my wife complains of the same issues but it's normal.it goes into gear hard 'cause of the high idle and Toyota automatics shift funny when cold for improved longevity.let it warm up a bit,but extended idling isnt best.5 minutes takes most of the chill out.
jermyjerm is offline   Reply With Quote
Old 11-10-2008, 09:25 AM   #7 (permalink)
doesn't sound normal...mine shifts smoothly when cold or warm...
Old 11-10-2008, 08:49 PM   #8 (permalink)
Asian N00b Modder
Gellenole's Avatar
View Gellenole's Photo Gallery
mine too -- 2003 btw.
I usually just make sure that when I park, the car doesn't shift forward or backwards beforehand. That's usually my cause -- after that it's all smooth sailing.
1995 Camry I4 @ 123k Miles - RIP 5-26-07
[Silverado Backed into it]
Originally Posted by catric69 View Post
It's cheaper if you get a new gf.
Gellenole is offline   Reply With Quote
Old 11-10-2008, 09:06 PM   #9 (permalink)
View enochc17's Photo Gallery
this happens for me as well. 2002 auto.
in the morning i have the time to warm it but in the afternoon leaving the parking lot is rushed to avoid the lineup out of it. so i don't have the time to warm it....
is this damaging to the tranny?...
we should do a thread for tranny maintenence measures. that would be helpful.
enochc17 is offline   Reply With Quote
Old 11-10-2008, 10:34 PM   #10 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
the clunking might be a warn motor mount. And it shifts at a higher RPM when cold because the Camry's auto trans will not shift into over drive until the car is at normal operating temp.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 11-10-2008, 11:37 PM   #11 (permalink)
Do not buy from
It's not recommended to rev when the parts ain't warmed up anyways.
Old 11-10-2008, 11:39 PM   #12 (permalink)
MrSo0h0o's Avatar
Bottom Line:
Let the car warm up until at least 1/3 up your temp. gauge. Make sure your RPMs are 1100 or lower before shifting into gear. If it still continues even when the engine is warm, get your motor/engine mounts checked out.
Old 12-14-2008, 10:33 PM   #13 (permalink)
Joined the dark side. :D
Gameroom cash: $656091
View workerant's Photo Gallery
What's the worst that could happen?
workerant is offline   Reply With Quote
Old 12-15-2008, 11:50 AM   #14 (permalink)
View danorthface's Photo Gallery
or just have your brakes depressed when shifting into drive. Once in drive, slowly let go of the brakes
danorthface is offline   Reply With Quote
Old 12-24-2008, 06:57 PM   #15 (permalink)
View scolist's Photo Gallery
On my 1990 and 2002 Camrys, I just turned off the OD until the car warmed up. It's stopped the same problem.
scolist is offline   Reply With Quote
