god damn water spots... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-10-2008, 11:49 AM   #1 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
Gen6 god damn water spots...
My Camry has a tun of water spots on it and i cant get them out no matter how many times i wash it. Anyone know how to remove them?
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 11-10-2008, 11:53 AM   #2 (permalink)
I ♥ (.Y.)
GT-R's Avatar
Gameroom cash: $821521
iTrader Score: 16 reviews
View GT-R's Photo Gallery
Try scratch remover, KIT scratch out (forgot the exact name) works good for me, most of the time. It should take out stains and scratches too, get the clearcoat safe.
GT-R is offline   Reply With Quote
Old 11-10-2008, 12:10 PM   #3 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
You need to clay and polish your car
MrSo0h0o is offline   Reply With Quote
Old 11-10-2008, 12:12 PM   #4 (permalink)
08 SE I4 Super White
fdrcamry08's Avatar
View fdrcamry08's Photo Gallery
Gen6
Try that new Turtle Wax ICE liquid Clay Bar...that stuff works some wild magic....
fdrcamry08 is offline   Reply With Quote
Old 11-10-2008, 12:18 PM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
where can i get it?
Old 11-10-2008, 12:28 PM   #6 (permalink)
I Miss my I4VVTI
iTrader Score: 6 reviews
View gene112601's Photo Gallery
Originally Posted by XxTrD_ToYoTaxX View Post
where can i get it?
Pepboys - Autozone - Kragen
gene112601 is offline   Reply With Quote
Old 11-10-2008, 12:28 PM   #7 (permalink)
JACK_FROST's Avatar
View JACK_FROST's Photo Gallery
where can i get it?
wal mart
JACK_FROST is offline   Reply With Quote
Old 11-10-2008, 01:02 PM   #8 (permalink)
View GeorgiaHybrid's Photo Gallery
If they are surface deposits only (no or very, very little etching) the "liquid" clay might work. I have not tried that particular product but have used a LOT of different clays over the years and if the spots are mild, they should clear up your problem
If the water spots have etched into your clear coat however, you will need to clean, clay, polish and then protect the paint. You might be able to get them out with a clay but most of the time a PC or rotary and good polishes and pads are needed. I would use a regular clay bar before polishing though just to make sure....
MrSo0h0o FTW....
GeorgiaHybrid is offline   Reply With Quote
Old 11-10-2008, 01:10 PM   #9 (permalink)
View 1/2 ton giant's Photo Gallery
i know exactely how. first wash your car, dry it in the shaid, apply a wax coating to remove any dirt that might be on your pain, then use an automitive clay bar that will take off anything but your paint. i do custom cars and i have to do this regulary. it works well. you can get the clay bar from pro line body parts.
1/2 ton giant is offline   Reply With Quote
Old 11-10-2008, 01:20 PM   #10 (permalink)
TN の がしょう
xpeed's Avatar
Gameroom cash: $590957
iTrader Score: 7 reviews
View xpeed's Photo Gallery
I tried that once and man, the finish is orgasmic.
1997 カムリ 5-spd *daily driver* Tokico HP - Tein S-Tech - TRD Kit - TRD FSB - ARC - 18" Enkei OR52 - Project Kics R40 - Custom Exhaust - Whiteline 20mm Rear Sway Bar
2003 Infiniti FX35 Sport Package - Metallic Copper
1996 Avalon MCX10 1MZ-FE
http://www.cardomain.com/ride/3900268/1997-toyota-camry
xpeed is offline   Reply With Quote
Old 11-10-2008, 02:33 PM   #11 (permalink)
1/2 ton,
I have to disagree with part of your post. You do NOT wax the car before claying. A good clay lube and your clay will remove surface contamination and your wax. You wash first, that I agree with. Then you use a good clay to remove embedded grit. After claying, if the paint requires it, it is then polished. After polishing, you must protect the paint with a good sealer or wax (or both).
I do agree that all of this should be done in the shade (if possible) although some polishes will work in the sun (PB's SSR series comes to mind) as long as the body panels are fairly cool to the touch.
Old 11-10-2008, 02:51 PM   #12 (permalink)
Loving the camry =)
View skyxliner's Photo Gallery
i know how you feeel, I frequently have to park on the side of the curb where sprinklers are constantly spraying the side of my car sometimes
i try my best not to park there but it's a must sometimes. but it leaves hella residue on the side of my car the next day.
skyxliner is offline   Reply With Quote
Old 11-10-2008, 03:35 PM   #13 (permalink)
Go camry goooooo
DrewsCam's Avatar
Gameroom cash: $184780
View DrewsCam's Photo Gallery
clay bar once or twice depending on how bad, also you can use a light compound, use also a paint cleaner.
Thats just have of what I do to clean damaged paint
11/19/2007 Gen 6 08 Camry SE.
Rockland Toyota / Scion Showdown 4.0 Sept 26th
DrewsCam is offline   Reply With Quote
Old 11-10-2008, 06:31 PM   #14 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Once you clay and polish it, if you use a good wax, then water spots would stick on less.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 11-10-2008, 06:53 PM   #15 (permalink)
Mr. Ed
sex_&_TRD87's Avatar
View sex_&_TRD87's Photo Gallery
yeah dont feel like reading all the response sooo...the big answer is
CLAY BAR!!!
Black 2007 Camry LE V6
Current Mods: LED swap, OEM fog lights - 2500K Nokya, 8000K TSX HID retrofits, TRD drop-in air filter, TRD drop, dual Magnaflow Race Series 14851, Sportmax 962 18x8.5 w/ Nankang NSII 225/45/18
sex_&_TRD87 is offline   Reply With Quote
