front end noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2008, 05:03 PM   #1 (permalink)
View dutchcrunch's Photo Gallery
front end noise
Hello, my friend has 2002 camry 4 clinder with 200,000 miles new brakes were installed 6 months ago, car drove fine till now. at highway speeds 65-70 miles/hr if you hit the brakes hard you can fell that the car is unstable with feedback thru steering wheel. firestone said it was front struts. i pushed on front of car and its hard with no bouncing. then took the car to goodyear, they said motor monts the struts are fine.
so before you say it i told him to take it to toyota and do not tell them and see what they come u with.
the car is aligned and drives straight and car rides smooth.
any help would be appreciated. thanks so much
dutchcrunch is offline   Reply With Quote
Old 11-11-2008, 05:11 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Your thread Title says noise and your description says unstable.......
Does new brakes mean just pads??
Probably warped front brake rotors.
If Firestone or your dealer cannot tell you that, never go back...
Machine or replace..................
and use a torque method of some kind to tighten your lug nuts whenever the front wheels come off.
Old 11-11-2008, 07:05 PM   #3 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $463374
View BlackCamSe's Photo Gallery
if the steering wheel shakes wile breaking, your rotors are warped. He may even need an alignment, and the wheels balanced.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is offline   Reply With Quote
Old 11-11-2008, 11:53 PM   #4 (permalink)
View Fobanginvtek's Photo Gallery
yeah rotors is my first guess. get your rotors cut, ive done em myself.
2007 Super white Camry CE
JL 13w7 in Prowedge box/Hifonics Brutus 1600rms
HID 8k and SE mesh grille
Fobanginvtek is offline   Reply With Quote
Old 11-12-2008, 08:06 AM   #5 (permalink)
front end
its hard to describe, perhaps it could be the rotors, will have them looked at,
but could the feedback from the front end during braking be caused by worn struts?? lets say the top mounts are worn causing the rotor /wheels to ocillate thru the steering wheel.
the braking is smooth but something is creating a feedback thru the steering well like warped rotors if that makes sense.
could the struts cause this??? thanks will keep you posted.
so if we have the rotors tuned and it still does this, were should we look.
Old 11-12-2008, 08:16 AM   #6 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
it most definitely is warped rotors, so go get them replaced/cut and then cross that bridge if/when you come to it
MrSo0h0o is offline   Reply With Quote
Old 11-12-2008, 05:04 PM   #7 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gen6
if it was the struts, it would do it ALL the time, not just wile breaking. When the rotors are warped, think if them being bent. When you break, the calipers grip them. So the calipers will stay fixed, causing the rotors and the wheel to vibrate. if their bad enough, you'll feel it through the steering wheel. Which is exactly what your describing
Old 11-13-2008, 08:05 AM   #8 (permalink)
Asteroid's Avatar
View Asteroid's Photo Gallery
It depends just what we're chasing. If it's a thumping, vibration or a noise while braking then look at the discs. However I suspect what the OP is thinking of is more of a handling problem then a braking problem.
Do you mean where the steering becomes vague, mushy and unresponsive under initial braking at speed, but is fine when not under braking? There is no real noise associated with the problem. My old Corolla did exactly that, but the 16 yr old soft Japanese suspension was FARKED! I'd be suprised if a gen 5 was bad enough to do this, but if it's done enough miles it may be. In which case I'd look at the front struts, bushes and tie rod ends for wear and play.
04 ACV36R Camry Sportivo 4cyl manual
92 CE100 Corolla DX diesel (jdm import) *sold*
Asteroid is offline   Reply With Quote
