Hello guys I have recently started driving my father 2003 Camry XLE I4 which he bought off a mechanic shop, the car have a salvage title probably due to a severe accident which the mechanics bought off and fixes it for resale. Apart from the dirty interior and minor scratches on the paint the Camry look ok. Closer inspection, some panel parts look uneven when fully close for example the hood and trunk have a wider gap on one side than the other. The steering wheel is uneven or something because everytimes I turn the steering wheel it would grind against the plastic column and produce scratch marks. Also if I make a turn, I could hear a loud screech as if I’m making a fast cornering turn. This is a common problem among the Camry community.
I also had to buy an owner manual since there isn’t one. Car came with only one master key and a valet key with a Toyota FOB for the Corolla or maybe an older generation Camry because it didn’t have a trunk release button.
Bare with me I have a couple of questions. Thanks a lot.
- Is there a solution for the screeching noise everytimes I make a turn?
- Is the trunk release button supposed to be on the 2003 Camry model FOB? Could someone show me a pic of the FOB.
- The windshield reservoir is filled with a blue fluid. Did the Camry roll off the assembly line with this fluid or is this something the mechanic put in. What is the color of the windshield fluid on your Camry?
- My engine coolant level is low and I need to pay a visit to the dealer for the coolant. The engine coolant’s color is cherry red which I’m guessing is the Toyota Long Life coolant. I can stick with the red coolant or should I switch over to the new pink Super Long Life.
- If I want to get a duplicate of the master key, where can I go for that?
- Car doesn’t have a cargo net for inside the trunk. Where can I buy one off online (No Ebay please).
- I think ABS is standard for XLE trim model but I don’t know if my car has VSC and Traction control. Is there a way to tell? (By the way there are no buttons on the dashboard to turn on/off those function but everytimes I cranked up the car I could see the VSC and Traction control light stay on for a second or so along with ABS and airbags). Don’t know if my car have alloy wheels or not but the spare wheel in the trunk have a black metal rim while the four wheels have a clear coat plastic like rim. Also the lever for turning on the light have a on/off switch for fog light but the car have no fog lamp so does it mean that the fog lamp switch is standard on all model even if they have don’t have the fog lamp or is it because the front bumper is a replace one with no fog lamp.
- Could you guys give me a list of tools to perform an oil change and spark plug? (possibly engine coolant and air filter change as well).
Thanks for taking the time to read.
