Installing Sirius Antenna - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-18-2008, 11:31 AM   #1 (permalink)
View hendrix8989's Photo Gallery
Ok guys heres the question...
The Sportster is going in the cubbie hole, and I see the side caps you can pop out on both sides to get the antenna through, but when the antenna goes thru the holes and comes out the side pocket...I only feel a bottom cap in the side pocket.....Can you pop that bottom out so the antenna can go through?
hendrix8989 is offline   Reply With Quote
Old 11-18-2008, 05:22 PM   #2 (permalink)
Baby's got a new skirt
ebumdude's Avatar
Gameroom cash: $180662
iTrader Score: 7 reviews
View ebumdude's Photo Gallery
I need a little more info bro...you have a GEN6? If so, you might want to try this link to at least help you get you get behind your cubby hole.
Radio, Door Panel, Rear Deck & Tweeter removal for CE, LE, SE & XLE DIY; 56k Beware
From there, you can run the antenna wire behind the cubby hole and out the side under the dash. That way you have no exposed wires and you dont have to deal with those side pocket caps.
Hope that helps.
- 07' Camry: LED interior/JDM fogs/Lighted stainless door sills/White cathode footwells front, back & trunk/Kenwood DDX6019/Rockford Fosgate P400-4/TMA T1000/(2) 10" Polk Momo 2104/Polk MM6's front's/Polk db6501's rear's/2.0 farad Tsunami Cap/18" Primax /6000k HID/Tein's
-09' Venza
ebumdude is offline   Reply With Quote
