VSC and Trac lights on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-21-2008, 07:51 PM   #1 (permalink)
View dunkonu23's Photo Gallery
Gen5 VSC and Trac lights on
Hello,
Today, I replaced the spark plugs in my 2002 Camry XLE V6 (121,000 miles)--that was absolutely no fun. I did remove the intake manifold and reinstalled it with a new gasket. There were no codes before or after the plug change. The VSC and TRAC off lights clear after shutting off the engine, but when I put the car in gear (Drive or Reverse), the lights come on again. I was very meticulous labeling everything and making sure everything went back as removed (no spare parts!). Apparently something is wrong, so I'm wondering, what are the common causes for this so I can get this fixed?
Thanks in advance.
Scott
dunkonu23 is offline   Reply With Quote
Old 11-21-2008, 08:08 PM   #2 (permalink)
View toyomoho's Photo Gallery
These systems have there own trouble codes, get a reader and find out what they are.
Is the check engine light also on?
Old 11-21-2008, 09:35 PM   #3 (permalink)
I have a reader (OBDCOM) and no, the check engine light was not on.
Scott
Old 11-21-2008, 10:21 PM   #4 (permalink)
just a nobody
You have to check the codes for the VSC/TRAC a different way, unless you have a Toyota scan tool; you can retrieve the codes by jumping terminal 4 and 13 of the OBDII connector, and then count the blinking of either the ABS or VSC warning light.
N.E.O.
Old 11-22-2008, 07:56 AM   #5 (permalink)
N.E.O.
Thanks! Where do I find which count means what?
Scott
Old 11-22-2008, 08:41 AM   #6 (permalink)
just a nobody
Off hand can't tell you where it is available online, but we can certainly find out for you.
N.E.O.
Old 11-22-2008, 09:46 AM   #7 (permalink)
N.E.O.
Thanks. Any help is greatly appreciated!
Scott
Old 11-22-2008, 10:41 AM   #8 (permalink)
just a nobody
No luck finding a link or thread. Post the code when you have it, will look it up for you.
N.E.O.
Old 11-22-2008, 05:43 PM   #9 (permalink)
N.E.O.
Will do. Thanks!
Scott
Old 11-23-2008, 02:07 PM   #10 (permalink)
The oddest thing... the VSC and TRAC off lights cleared and I've done nothing.
Scott
Old 11-23-2008, 05:24 PM   #11 (permalink)
just a nobody
Well, just keep an eye on it, if it pops up again, check the codes and will find out what is going on!
Keep us posted!
N.E.O.
Old 01-15-2009, 08:58 AM   #12 (permalink)
2008 Camry SE-V6
View carlkra's Photo Gallery
My experience with the VSC/TRAC/Check Engine lights went like this:
Vehicle: 2008 Camry SE-V6
I was on the off-ramp two days ago, and as I slowed, the VSC, Traction Control and Check Engine lights all came on simultaneously. The road was dry, not slippery and I was slowing gradually without braking. The lights stayed on as I drove. Although it was after hours for my Toyota dealer, there was an auto service center with extended hours nearby. In the shop parking lot I turned off the engine and then restarted. The Check Engine light stayed on but the VSC and Traction Control lights did not come back on. The shop read the fault code as P2197 (Oxgen Sensor Signal, Bank 2 Sensor 1) and told me the car was safe to drive until I could get it into the dealer.
Today, The VSC and Traction Control lights came back on (along with the Check Engine light which is on all the time) and now they come on every time I start moving. I checked traction control and it is not working. The wheels spin up on ice just like a car with no traction control. I haven't tried VSC but I'm assuming its NFG as well. I have an appointment to bring it in but I'd like to have some idea if this is a common fault or a fluke.
Any advice appreciated.
Thanks!
carlkra is offline   Reply With Quote
