Installed Viper 5701 LE alarm on 08' camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-01-2008, 06:36 PM   #1 (permalink)
snake212's Avatar
View snake212's Photo Gallery
i finally got the viper 5701 alarm installed with remote start. but i have some issues. first off the installer said this is his first time installing this alarm and he didn't have the device to make my car start remotely. second, he said i wouldn't be able to program the viper remote to open my trunk, unless i buy a separate device. also when i lock or unlock the car with the viper remote the parking lights don't flash, and when the alarm goes off nothing flashes. but i didn't tell him yet because im going back there when he gets the part for remote start. so when i go there i want him to do it perfectly. so i was hoping anybody here that has this alarm would give me some advice on what should work with this alarm because what this guy is telling me i think isn't true.also is it possible for the headlights or hi beams to flash when the alarm goes off? or is that gonna be bad for hid's when i get them? i would really appreciate the help.
snake212 is offline   Reply With Quote
Old 12-01-2008, 06:54 PM   #2 (permalink)
must.resist.modding
bandit's Avatar
Gameroom cash: $477210
iTrader Score: 12 reviews
View bandit's Photo Gallery
#1. You either need to give up your valet key or get a Transponder Override Interface (XK05) for the remote start. The XK05 does not require you to give up your valet key. In order to have remote start, you need to have the key connected to the car. This tricks the car into thinking the key is in the ignition. I dont know what the installer meant that he "didnt have the device to make your car start remotely". I assume he meant the transponder override. Even if he didnt have it, if you gave up your valet key, he could have still set up the remote start.
#2. To pop the trunk, you need to purchase the trunk release solenoid (#522T)
#3. Is the stalk for your headlights turned to OFF? If its on DRL, Auto or Headlights, the parking lights will not flash when you unlock/lock the doors. I too thought something was wrong when I first saw my lights not flash.
#4. I had my alarm locked with the Viper 5701. I unlocked the door with my OEM key and the alarm went off. The only lights that flashed with the alarm was going off was the parking lights, taillights and license plate lights. No low beam or high beam flashed.
I have TSX retrofits and it never flashed so if you're putting plug and play HID kits, you have nothing to worry about.
The 5701 is the easiest alarm to install compared to others (from what I heard). So if your installer has installed other Viper products, this shouldnt be any different whether it be another Viper alarm, Python, Valet or Clifford. All the same company.
Retail price for the transponder is $99.99 and trunk solenoid is $59.99 according to Viper's website. I bought my transponder on eBay for $35 and seller installed the firmware for my car. I would of bought the trunk but I didnt know I needed it so I had my installer charge me for it. If I knew, I could of probably gotten it for like $15-20 on eBay and just gave it to my installer.
CarDomain
Old 12-01-2008, 07:29 PM   #3 (permalink)
snake212's Avatar
i freaking love u man! the parking lights work. thats what it is the transponder override interface he said the remote start will work with that. so its true i will need the solenoid for the trunk. and also are there any tips or tricks for the alarm remote cause i didnt get the box or manual. thanks alot.
Old 12-01-2008, 08:28 PM   #4 (permalink)
must.resist.modding
bandit's Avatar
No tips or tricks. Just some info/settings incase you want to configure it to you likings such as silent locking/unlocking (no beeps/chirps). You can go to viper.com and download the PDF manual
CarDomain
Old 12-01-2008, 08:32 PM   #5 (permalink)
LOV
268 HP OWNER
LOV's Avatar
View LOV's Photo Gallery
+1
2007 Camry SE V6 , MGM
LOV is offline   Reply With Quote
Old 12-06-2008, 06:36 PM   #6 (permalink)
snake212's Avatar
Do you have the phone number of the installer that did your car. Because my installer just can't get it to work. The brain is getting the signal but can't get the car to start.I would really appreciate it.
Old 12-06-2008, 10:33 PM   #7 (permalink)
must.resist.modding
bandit's Avatar
http://customwhip.com/main.htm
Number is on the site.
CarDomain
