Blue 1988 Camry Alltrac(not stock at all)
1990 3sgte swap
MLS head gasket
Maule pistons .020 over 9to1 compression
Shot peened stock rods
ARP fasteners
Block was fully prepped from individually matched cylinder bores
to the ultra smooth deck for the the MLS head gasket
Fully balanced rotating assembly
Flow tested and balanced injectors
MAPECU-3 fuel management
ACL race barrings
Turbo upgrade to ct20b
ATS throtle body inlet
Front mount intercooler
Coustom dule core aluminum radiator
HKS SSQ BOV
Greddy ProfecB boost controller
Aromotive fuel pressure regulator
Lightened race flywheel and sprung hub six puck racing clutch
SS clutch line
Short throw shifter
Boost gauge and wide band AFR gauge
Wheels 16" drag dr-31 16x7 40mm offset
Tires 225/45/16 BFGoodrich kdw2
matching full size spare
Megan street dampener coil-overs for an st185 Celica Alltrac
poly control arm bushings
Energy Suspension sway bar bushings
EBC yellow stuff Pads
Cross drilled and slotted Brembo rotors
Custom SS braided brake lines
3" catles down pipe
Full 3" mandrel bent exhaust
18% window tint
Battery relocated to trunk
HID lighting
