So I'm using the camry cuz the avy needs to go to shop, and whenever i start the car, a bad smell comes through the vents.
This happens every time that air passes through the vents. I checked/changed the cabin filter and nothings wrong with it, except for that persistant smell of mold/mildew. I want to get to the bottom of this but i dont want to go through and check the ducts themselves. What should I do?
'02 Toyota Tundra iForce V8 TRD AC THUNDER "FRACKING" GREY METALLIC 97000 miles
It sound lek u hav a daid rat uppin ur dash. Iffin it twas min instaid of urin, id take the whule dash outin the car and hos it of wit a gardin hose and then find the daid rat and threw it away.
you can buy a cleaner foam and disenfectent for the evaporator box and the air vents....
most auto stores have it...it cleans the mold out of the evaporator box and lines, because due to the condensation in the a/c system mold tends to form in the lines and evaporator...the foam kills said mold, and the spray is introduced into the cowl and disenfects the vents so the smell goes away.
our dealer sells the a/c deoderizer service....i have about 8 of those kits in my toolbox and i clean my a/c system every 2 months to keep it fresh inside...im also incredibly anal about my car and i adress every issue head on or try to prevent it
Is it possible that the AC drainage line could be clogged? I know this is an issue on some other vehicles.
If so, where is the A/C drain located and what is the best way to unclog it? I have heard that sticking a wire coat hanger into the drainage line/hole can unstuck any debris that may be in there.
