Installed AVN6620 on a non-JBL,non-nav...problem with vehicle speed sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-06-2008, 09:18 PM   #1 (permalink)
MCeatalot's Avatar
iTrader Score: 7 reviews
View MCeatalot's Photo Gallery
Gen6 Installed AVN6620 on a non-JBL,non-nav...problem with vehicle speed sensor
Ok, so I just finished installing my AVN6620 on my Camry. It came with the Parrot BT kit also. Everything works fine, including the DVD playing while in motion, except for the speed sensor. All my searches in the forum led to this post:
speed sense wire?
I also read from another post that the purple wire that is on the OEM 10-pin wire harness is the VSS. So knowing that, I used the included connector and spliced the purple wire. But to no avail.
For those running on aftermarket navigation, how and where did you find the VSS? Also, my check engine light went on. Any reason why? The batter was unplugged during the installation.
I replaced my 4-cyl with another 4-cyl, equally powered, but faster ride...
http://i234.photobucket.com/albums/e...e/P9231851.jpg
MCeatalot is offline   Reply With Quote
Old 12-07-2008, 12:38 PM   #2 (permalink)
MCeatalot's Avatar
Here are some pics of my set up:
Here is the 10-pin OEM harness, where I found the solid purple color that's supposed to be the vehicle speed sensor:
And here's the purple connector spliced with the purple with white dash that'll connect to the HU:
In this picture, on the middle of it you will see a red wire with black stripes that leads to the bolt. That is where I grounded the parking wire so my passenger's able to watch while I drive:
Here's the final set up:
Anyway, I decided to remove the speed sensor wire from the HU for the time being. But any help regarding its location will be helpful.
Old 12-08-2008, 08:51 PM   #3 (permalink)
View jll544's Photo Gallery
Wrong wire. You want the purple/silver wire on the steering wheel control harness (upper right in your 3rd picture.)
jll544 is offline   Reply With Quote
Old 12-08-2008, 10:53 PM   #4 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
How much did you spend for everything?
Redline_Me is offline   Reply With Quote
Old 12-08-2008, 10:58 PM   #5 (permalink)
MCeatalot's Avatar
Thanks jil544 for your input.
Redline, I paid $600 for everything shipped, brand new and from a reputable online store.
Old 12-08-2008, 11:05 PM   #6 (permalink)
View RoseMobile's Photo Gallery
I see now y you want the camera good navi choice...
RoseMobile is offline   Reply With Quote
Old 12-08-2008, 11:34 PM   #7 (permalink)
That's pretty good.
Can i bother you for a list?
Old 12-22-2008, 01:30 PM   #8 (permalink)
View nelsonrx's Photo Gallery
Where store did you buy all that equipment from? $600 is an awesome price for all of that!
nelsonrx is offline   Reply With Quote
Old 12-24-2008, 10:05 AM   #9 (permalink)
MCeatalot's Avatar
Just an update and for those wanting an Eclipse AVN6620 in the future:
I finally got it to work. After following Jil544's instruction to tap the purple wire with silver dashes, it still did not work!
Here's the trick!
You HAVE to cut the speed sensor wire from the connector first, then tap it! Otherwise, if you leave it intact and plug the connector to the head unit, it will stay grounded and the HU will be unable to read the speed.
And to those curious, I got it from Sonic Electronix store. They have a website and are based in Valencia, CA. If you live nearby, you can pick up the item. I was going for the AVN5510 because of the deal they had, but were OOS at the time, so they offered to upgrade me to the next one, which is the 6620, along with the necessary install PLUS the Bluetooth module.
Old 12-24-2008, 11:23 AM   #10 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
Nice...very nice!!! Good job man.
Old 01-07-2009, 03:25 PM   #11 (permalink)
View brent_smith10's Photo Gallery
Do the steering wheel controls work for the eclipse? Also will the factory xm plug into this unit if you have it?
brent_smith10 is offline   Reply With Quote
Old 05-26-2011, 12:26 AM   #12 (permalink)
View MDTRD's Photo Gallery
bump
09 Camry SE V6
07 Taco DC TRD OR
06 Sequoia Limited
00 Taco Xtracab s/c'd TRD V6 5sp -- PARTING OUT!!!
MDTRD is offline   Reply With Quote
Old 05-26-2011, 05:52 PM   #13 (permalink)
Question for you guys. I have a 09 SE w/JBL and just installed my AVN6620. Which wire do I use to control the day/night illumination of the 6620? I SEARCHed but didn't come up with any thing. Thanks.
09 Camry SE V6
07 Taco DC TRD OR
06 Sequoia Limited
