Just finished the local dealer's routine inspection, the report said rear brake pad has 6mm left and front brake pad has 9mm ... is this possible?
My car has 30,000mi on the clock and no brake pad has ever been changed since the car is new...
In the United States stability control and traction control are options and not included standard on any Camry's. I can't say the same about Hong Kong. If you do have stability control and regularly drive in a spirited manor it would be expected that increased brake pad wear would be seen.
that doesnt make any sense...unless you have been driving around with your parking brake on. It may be possible they got the front and rear measurements mixed up. The worse case scenario is that you may have a major brake system problem, which at 30,000 miles should be under factory warranty
ASE/ Certified Toyota Tech in Dallas Area
I'm not questioning brake pad wear ... I am asking whether it's normal for rear brake pad wear out quicker than front brake pad...
Did you even bother to read my response? If you have stability control you can wear out rear brakes sooner than fronts, depending on your driving style.
If you don't even know if your vehicle has an option, maybe you should concern yourself with familiarizing yourself with the features of your automobile before questioning the advice of a service tech.
So which is it? Do you have stability control or not?
sorry, i may have missed to read that... i am a bit sleepy... it's 1:29am here...
i drive slow all the time and seldom apply heavy brakes.
stability control will also do this...i feel dumb for not thinking about it before. but it still should not make such a significant difference in the front and rear brake pad wear
We have 2 specifications only. option 1 is 2.4L engine, option 2 is 3.5L V6 engine. All options are standard.
i cannot find the name VSC or traction control in the local Toyota website, so i guess it's included since usually we have "full option" on safety aspect.
