You can if you want. I highly recommend a brake fluid flush/bleed if you haven't yet done it yet. I like Castrol LMA or Valvoline Synthetic. You will need 1 quart to bleed the entire system.
Power steering fluid, I would get 1 or 2 quarts of Dexron III and a turkey baster. Then remove and replace the fluid in the reservoir every oil change. Don't let the fluid level get lower than the hoses in the reservoir. You don't want to get air in the system.
Does the turkey baster technique (using a baster from an autoshop, not a real turkey baster) work for the brake fluid as well, or does the brake fluid have to be bled?
no gotta bleed brake fluid mos def
2007 Super white Camry CE
JL 13w7 in Prowedge box/Hifonics Brutus 1600rms
HID 8k and SE mesh grille
Nope, don't do that. You can get a 1 man bleed kit for about $10 if you don't have someone to help you.
