Check Engine Light Diagnosis? - 2006 Camry - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2008, 10:16 PM   #1 (permalink)
View 2CamryFan's Photo Gallery
My wife's 2006 Camry (4 cyl) has 55K miles and recently starting showing the check engine light. The car runs great. I checked the gas cap. No problem.
Anything I can check or do before taking it to the dealership for a potential fleecing?
2CamryFan is offline   Reply With Quote
Old 12-13-2008, 10:42 PM   #2 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Check for set MIL codes.
Old 12-14-2008, 12:20 AM   #3 (permalink)
just a nobody
Agree! Knowing what code you have will determine what you have to do.
N.E.O.
Old 12-14-2008, 04:02 AM   #4 (permalink)
View MrObvious's Photo Gallery
Go t Autozone. Its free.
MrObvious is offline   Reply With Quote
Old 12-14-2008, 05:00 PM   #5 (permalink)
Gameroom cash: $303755
^ Yes, Autozone and some other auto parts stores will read the codes for you for free. Call around to auto parts stores in your area and ask if they offer this free service. Then report back here with the code or codes and someone will be able to give you some direction.
Mike
Old 12-14-2008, 05:19 PM   #6 (permalink)
Will do. Thanks for the advice.
Old 12-15-2008, 05:59 PM   #7 (permalink)
I took it to Autozone, and they tested it.
Came up with code " PO401 "
I had the salesman reset the indicator light and it didn't come back on when I drove home.
Any thoughts?
Old 12-15-2008, 06:12 PM   #8 (permalink)
View camlex's Photo Gallery
will show up shortly....
camlex is offline   Reply With Quote
Old 12-15-2008, 06:18 PM   #9 (permalink)
'07 XLE
Gen6
Insufficient flow in the exhaust gas recirculation system
http://www.obd-codes.com/p0401
Follow the troubleshooting in your Service Manual just like Toyota would or take it in to the dealer.
Probably $$$
Old 12-15-2008, 07:29 PM   #10 (permalink)
I guess this wouldn't be covered by the emissions warranty? It is past the 36k bumper to bumper warranty, and I didn't know about Troy's low warranty prices when I bought it.
Old 12-15-2008, 08:07 PM   #11 (permalink)
'07 XLE
Sorry, emissions warranty only covers ECM and cat. converter.
Lots of posts in the earlier GEN Camrys about this MIL code and parts replacement.
Glad there is no EGR on my GEN6.
Old 12-16-2008, 02:45 AM   #12 (permalink)
View ProperElite's Photo Gallery
Did you recently have the oil changed?? My check engine light came on shortly after I had purchased my '06 Camry (I bought it used) and I know the dealership had just serviced the vehicle. I was reading in the service manual that after 4800 miles or so of not resetting the system, the check engine light will come on and the manual says that it is just an oil change prompt.
Each time you have the oil changed, you will need to reset the system.
2006 Toyota Camry LE 2.4L
ProperElite is offline   Reply With Quote
Old 12-16-2008, 07:53 AM   #13 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
The light indicating you to change your oil, aka "maintenance req'd" is NOT your check engine light, aka MIL(malfunction indicator light)
MrSo0h0o is offline   Reply With Quote
Old 12-17-2008, 11:18 PM   #14 (permalink)
It came back on after 60 or so miles as previously suggested. Off to the dealership tomorrow. Grrr.
Old 12-19-2008, 08:30 PM   #15 (permalink)
Interestingly enough, the dealership said the code indicated a loose gas cap (P0442 on receipt). They inspected the gas cap, put some silicon lubricant on the gasket, reset the code and charged me a little over $40. They insisted that it was only the gas cap - even after I questioned their diagnosis.
