Gen 6 Wheel Fitment advice - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-19-2008, 11:36 AM   #1 (permalink)
View Bran808's Photo Gallery
Hey guys, I just joined this forum and have been lurking for a little bit. I'm actually not a Camry owner yet, but am thinking of getting one for my wife. In anycase, what are some aggressive fitment wheel set ups that you camry owners are running? If we get the car, I'm looking at just a mild drop....maybe H&R's or maybe the Teins, and a set of 19's. Can you fit a 10" wheel with a +45 offset, wrapped with 245/35's in the back with either of those springs? I have a fender roller and rolled/pulled my own WRX wagon to fit 18x10's with a +35 wrapped with 255/35's and it was slammed. You guys think it's possible? If not, what is the most aggressive set up that you guys have seen?
Also, is it bad to run a staggered set up on a FWD car? I know people usually only run it on a RWD, but does it damage or harm anything? I know for AWD it's a no no, but what about on a Camry?
Bran808 is offline   Reply With Quote
Old 12-19-2008, 12:45 PM   #2 (permalink)
I Miss my I4VVTI
iTrader Score: 6 reviews
View gene112601's Photo Gallery
Gen6
hi there before some one jump to you ill write something for u
for first congrat to join the best toyota forum..
actually im running Staggered Set-Up on a gen6 Camry and handle 100x better then all around same set-up .
my Set-Up is 18x8.5 +35offset Front - 18x9.5 +35 Offset Rear.
also u can go with 19" with same set-up but there is one member with 10 at rear but... not my taste u have to make a Crazy Camber + Slam the Car... but the problem is the $$ on tires haha
also if u roll the the fender u will have more chance to not RUB i shaved my rear fender and i got no RUB at all u might try with more higher Set-up its all depend on ur $$ hope all this help and good luck!
*u can check my Cardomain for Pic's
gene112601 is offline   Reply With Quote
Old 12-19-2008, 01:06 PM   #3 (permalink)
^^^ Thanks for the reply. It seems like I should be ok if I were to go with this set up. A 9.5" wheel with a +35 offset is pretty close (overall size and spec wise) to a 10" wheel with a +45 offset. I don't mind rolling the rear fenders at all if need to.
Any other input?
Old 12-19-2008, 01:10 PM   #4 (permalink)
I Miss my I4VVTI
Gen6
Any other input?
that was the higherst atm on this forum
Old 12-19-2008, 03:33 PM   #5 (permalink)
i love emmanuelle chriqui
LXS-mode's Avatar
View LXS-mode's Photo Gallery
19x10 +45 will hit your struts...
What is it about...Stance? Flushness? Stretch? or Pokin Out?
Clean...Elegant...Simple...yet so GANGSTA!!!
LXS-mode is offline   Reply With Quote
Old 12-19-2008, 03:41 PM   #6 (permalink)
Do you know how close it is? I'm running 5mm spacers front and rear on my Suby to clear my coilovers. Is this a possibility or if not, what is the next most aggressive set up somebody has proven to work?
Old 12-19-2008, 03:47 PM   #7 (permalink)
07 Camry SE V6
View aznhyperracer's Photo Gallery
^^hey is this brandon with the silver STI...wait i think you got a blue wagon now......^^
^_^iF sPaRkS dOn'T fLy YoU'rE rIdInG tO hIgH ^_^
aznhyperracer is offline   Reply With Quote
Old 12-19-2008, 03:51 PM   #8 (permalink)
Haha, yup that's me, and I'm still driving the WRB wagon. How you doing Russell? Your car looks pretty friggin sweet. What's the specs on your wheels/tires? And I'm assuming you're bagged right? Hit me back with some info on your mod list. I'm trying to decide on getting one for the wifey, and already looking into mods too.
Old 12-19-2008, 08:35 PM   #9 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
18x9 +30
18x8 +30
you can get away with those w/ a drop and no rolling.
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 12-20-2008, 10:14 AM   #10 (permalink)
Here and there...
Gameroom cash: $153229
View lammydi's Photo Gallery
Originally Posted by PrincessPeach View Post
18x9 +30
18x8 +30
+1 Especially if you go with 225-45-18 tire size.
I currently have
18x8 +35 Front 235-45-18 tire size
18x9 +35 Rear 235-45-18 tire size
I am lowered with Eibach springs and have no rubbing at all.
Old 12-21-2008, 11:14 AM   #11 (permalink)
18x9 +30
18x8 +30
I currently have
Thanks for the info guys. Will running 19's make things any harder t fit? If anything, I'm looking into 19's.
Old 12-21-2008, 01:06 PM   #12 (permalink)
씨발
19x9 +35 rear
19x8 +30 front
you can get away without rubbing and a slight drop.
If I were you, screw the slight drop, get coils, SLAM, camber, and 19x9.5 rear, 19x8.5 front
AdvanceSpeedShop
Old 12-21-2008, 08:57 PM   #13 (permalink)
19x9 +35 rear
19x8 +30 front
If the car were mine, I wouldn't even be asking.....colovers would be a given. Haha, but since the next car we buy will be for my wife, I'll be lucky if she even lets me drop it a little. That's why I was thinking H&R
s and 19's. Just something mild...
BTW, is that your current set up....19x9 and 19x8? What size tires are you running and do you rub at that height? Did you have to roll your fenders for that set up?
Old 12-22-2008, 03:29 AM   #14 (permalink)
씨발
that was my previous setup.
19x9.5
19x8.5 +35 all around.
and yes, i had to roll and trim the fat
AdvanceSpeedShop
Old 12-22-2008, 03:51 AM   #15 (permalink)
Under Reconstruction
Epsilon's Avatar
View Epsilon's Photo Gallery
Stick a 9" up front and a 10.5" in the rear and call it a day.
Epsilon is offline   Reply With Quote
