Hello. I have been noticing a rumbling noise coming from the passenger side of my 2002 Camry LE for approx the last 20K miles. The car currently has 120K on it. The car has drum rear brakes. The noise is a low-freq low-pitch rumbling. It ooccurs randomly but usually under the following condidtions:
- When slowly accelerating from a stop until reaching approx 15mph.
- When making a constant speed left hand turn (as in driving around the neighborhood at 25mph).
I am having a hard time isolating exactly where the noise is coming from. It is not a quiet noise but due to being just such a low rumble that makes it hard to distinguish the source. It is obvious that it is coming from the passenger side but I cannot tell for certain if it is the front or back wheel. I have had family and friends in the car and they seem to think it is coming more from the rear wheel.
I have lifted the car for a quick check to see if I could rock either front or rear wheel and they seem fine. I have spun the tires while the car is lifted and I can only hear the rear passenger shoe swiping on the drum slightly but other than that it sounds fine. I lifted both sides of the car for comparison.
I originally started to notice the sound after putting Hawk Ceramic front pads on the car and attributed the noise to them since they are a little more aggressive than OEM. The more I drive the more I realize this is not the case. My rotors also start to warp after little mileage (15K miles). I replaced the rotors when I put the Hawk pads on but the rotor warping has been going on for a long time and cannot be attributed to the Hawk pads. I have a feeling that whatever is making the noise has something to do with the rotor warping.
I am considering buying a new rear wheel hub assembly. I would rather check my hub assembly before doing so since they are expensive. Can someone tell me how I would do this? Does anyone have experience with these symptoms, and, if so, any recommendations? Any help is greatly appreciated.
