02 Camry - Heater Belt Squeals - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-22-2008, 11:46 AM   #1 (permalink)
View fernj's Photo Gallery
When I turn on heater if the car is still a little cold it souds like some belt is slipping or something. What can it be. Once it is at normal operating temp. it is all good. no more squealing.
fernj is offline   Reply With Quote
Old 12-22-2008, 03:42 PM   #2 (permalink)
just a nobody
Do you mean the A/C belt? There is no belt for the heater. Did you have it on defrost when it makes the noise?
N.E.O.
Old 12-22-2008, 03:59 PM   #3 (permalink)
It screeches no matter what setting the heater is on.
Old 12-22-2008, 04:01 PM   #4 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Heater setting or fan setting?
Old 12-22-2008, 04:11 PM   #5 (permalink)
The fan is turned on. temp is set to heat. any vents.
Old 12-22-2008, 04:45 PM   #6 (permalink)
just a nobody
Where is the noise coming from? Inside the car or outside the car? Does the noise change with the fan speed?
N.E.O.
Old 12-22-2008, 04:48 PM   #7 (permalink)
It comes from outside the car, I don't know about the fan speed. I will have to check.
Old 12-22-2008, 04:51 PM   #8 (permalink)
just a nobody
Is the blue 'A/C' light on when it makes the noise? Switch that off if it is on and see if the noise stops.
N.E.O.
Old 12-22-2008, 04:52 PM   #9 (permalink)
I will try that
Old 12-22-2008, 04:55 PM   #10 (permalink)
just a nobody
If the noise does stop, you probably need to have your belts check. Maybe adjust or replace depending on their condition.
N.E.O.
Old 12-22-2008, 04:56 PM   #11 (permalink)
'07 XLE
Gen6
Worn serpentine belt slipping when A/C compressor is on in the cold.
Old 12-22-2008, 05:37 PM   #12 (permalink)
Gort1's Avatar
View Gort1's Photo Gallery
Sounds like it might be the heater motor itself sqeeling when cold, the bearings or bushings are probaly dry
[B]2009 Venza V6 AWD,Premium Package#2,DVD Nav, Panoramic moon Roof, Blizzard Pearl
1998 T100 4x4 SR5
Gort1 is offline   Reply With Quote
Old 12-22-2008, 05:40 PM   #13 (permalink)
how would you correct this?
Old 12-23-2008, 05:44 PM   #14 (permalink)
Gort1's Avatar
Well depending on how mechanically inclined you are, you can just drop the blower motor out of the heater and lube the bearings/bushings if you can get to them. Since your Camry is an 02 might be easier to just replace the blower motor.
1998 T100 4x4 SR5
Old 12-23-2008, 08:26 PM   #15 (permalink)
just a nobody
The blower motor is inside the car, if the noise is from outside the car, then.......? Are you sure the noise is from outside the car?
N.E.O.
