JBL Speaker syetem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-25-2008, 05:57 PM   #1 (permalink)
View vibe style's Photo Gallery
JBL Speaker syetem
Hello, I'm new to this board but have been on 6gc.net for the past 5 years for my Celica, I am proud to say I have grown up and got an 07 Camry!
Question one is my used Camry SE came with the Jbl speaker option which sounds great, but the left rear speaker sounds blown, is it possible to replace this with an aftermarket 6x9 or should this be covered under my warranty?
Question two, is there anything special I have to do to add subs? Are they just plug and play with out any problems?
Thanks for any help you guys can give!
vibe style is offline   Reply With Quote
Old 12-25-2008, 06:42 PM   #2 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
You CANNOT fit a standard 6x9 speaker in the back without using brackets. And secondly, the rear speakers are coaxial.
You need to splice off the rear speakers for a sub signal. Your blown speaker should be covered under warranty.
I had my front right speaker replaced under warranty 2 weeks ago and apparently that's a $230 item. Therefore I can only imagine what the dealer will want for the rear coax ones.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 12-25-2008, 06:43 PM   #3 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
If it's less than 36K miles than it's covered under warranty. Mine too is blown on that same speaker. One of my passenger notice it and I got them to check it at 35K.. they had to order it and replaced.
Last edited by workerant; 12-26-2008 at 04:41 AM. Reason: thanks to Fobanginvtek pointing it out that it's 36k
workerant is online now   Reply With Quote
Old 12-25-2008, 06:47 PM   #4 (permalink)
They told me without the warranty it would run around $700. And the labor too would be extreme cause they had to take out the seat.
Old 12-25-2008, 08:33 PM   #5 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
As far as I can tell the only "specialty" on the rear speakers is that you need shallow mount 6x9 (2 way coax) so that they do not interfere with your trunk mechanics. Look into Boston Acoustic SL95 - nice, very shallow and 3 way coax, very good sound quality. I just got a pair for $150 (MSRP is $300).
Front door speakers are woofers only and quoted costs is not comparable. Be careful with the low end 6x9's ...they want sound good compared to the OEM JBL.
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 12-25-2008, 11:29 PM   #6 (permalink)
View Fobanginvtek's Photo Gallery
Originally Posted by TTM77 View Post
If it's less than 32K miles than it's covered under warranty. Mine too is blown on that same speaker. One of my passenger notice it and I got them to check it at 31K.. they had to order it and replaced.
thought it was 36k?
2007 Super white Camry CE
JL 13w7 in Prowedge box/Hifonics Brutus 1600rms
HID 8k and SE mesh grille
Fobanginvtek is offline   Reply With Quote
Old 12-25-2008, 11:32 PM   #7 (permalink)
If you don't get it under warranty, don't even waste your time with it, its just a rear coaxial, you can replace it with anything. just worry about the fronts. I don't have the JBL option, but my speakers all around are 6x9's, (very front two by the windshield are 2.6'' i think). If you want subs youll need a number of things.....what sub are you planning on getting?
Old 12-26-2008, 12:13 AM   #8 (permalink)
Well I have a box with two Kicker 12's and a 2000w amp in my Celica now and was just thinking of swapping.
Old 12-26-2008, 01:58 AM   #9 (permalink)
How come you asked what you needed to have,for a sub in your camry then?
Old 12-26-2008, 02:07 AM   #10 (permalink)
That was based on my past experinces with premium sound sytems, my Celica had a factory installed amp that needed to be removed before subs could be put in and a friends RSX with the Bose system was told he could'nt have any sub but the Bose one it came with. On top of that this is a new car for me and I wanna avoid any unforseen damages i could do to it.
Old 12-26-2008, 02:50 AM   #11 (permalink)
Hmm i dont think thats true, my friend has a lexus and has a factory Bose system with a factory amp (under the driver seat i believe) and he can add subs, also you CAN add subs to a Bose system...Do a clean install, remember connections are very important...go for copper, and make sure the wire is actually thick not the rubber surrounding. Seperate RCA's and power wire on passenger and driver side when running it through your car
Old 12-26-2008, 04:41 AM   #12 (permalink)
Originally Posted by Fobanginvtek View Post
thought it was 36k?
Corrected.
Old 12-26-2008, 07:25 PM   #13 (permalink)
Cool thanks for the tips guys, I have another question and didn't want to create another thread.
I believe my Bluetooth mic is broken. I hit the talk button and it says "welcome to the hands free system please record the name of the phone" at this point I can scream as loud as I want right into the mic and it will continuously say "pardon?" What are my options?
Thanks again for all the help!
Old 12-26-2008, 08:24 PM   #14 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
The mic is located in the front roof console where your front reading lamps are, sunglasses holder and sunroof controls. That thing would need to be replaced. Again, it should be warranty work.
Old 12-26-2008, 09:08 PM   #15 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
You don't have to yell, just speak clearly.
It must hear you if it says pardon, it just doesn't comprehend what you are saying. Have someone else try...........
