still having this issue ocasionally
Old post but I decided to post an update in case someone else has this issue.
even though this issue is sporadic, I think it has something to do with the wiring under the seat. The wiring is lose under the seat and unfortunately I don't have 2nd camry anymore to see if that's how it should be. When I unplug the plug and plug it back the flashing seems to go away, but can't say for sure. I turn off the ignition before playing with this plug and because the issue is sporadic I can't say if playing with the plug really fixes the issue. I taped the plugs and wire to minimize its' movement, so hopefully this issue will go away
Original owner may have taken this seat out for some reason and that caused this issue or may be something like a water bottle got stuck under the seat when I or my wife adjusted it.
