for gen 6 models, the key and remote both have to be programmed by the dealer, by a master technician and on the techstream computer
same goes for gen 5 models with a chip key for the alarm system...i believe you can use the above process but i just use the work techstream because its easier...randy, your key would be fat and not skinny if your car had a chip key, and you would have a red "THEFT" light next to your climate control on the right side
chip keys only came standard on....
2002-2006 SE V6
2002-2006 LE V6
2002-2006 XLE (all models)
all other models have non chip keys, and you can just take one of your keys to toyota and they can make an oem copy for 10 bucks...the process you have randy is the programming for the chip keys...non chip keys, which you most likely have, dont need to be programmed
The "Executive Sedan"
