Suspension squeaks still exist after greasing.. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-04-2009, 04:16 PM   #1 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $283505
View MrSo0h0o's Photo Gallery
Hey guys, I have been having squeaking from the rear of my car since i installed my RSB. I finally got around to get under the car and apply white lithium grease to all contact points of the RSB. I took it out for a drive but I did not notice any difference!
I did a quick search and I am thinking it may be worn sway bar end links. Kinda like this (not my car:
Could installing the RSB make the bushings go bad? I am not sure what bad bushings look like..
Another theory is that my springs are just bad? i have 47k on the car. It does not feel TOO bouncy but I am just not sure.
Whats your input?
MrSo0h0o is offline   Reply With Quote
Old 01-04-2009, 06:36 PM   #2 (permalink)
Gameroom cash: $255930
View LE05's Photo Gallery
don't forget there are bushings for the other parts of the rear suspension as well: rear suspensions arms and strut rods. In the very bottom of your picture, there is a bushing on what looks like a strut rod below the end link. Look for similar bushings on your rear suspension and grease them with a silicon spray.
i came back from a trip in vermont in that big snow storm a few weeks back... my car squeaked like a 30 year old rust bucket... even over very small bumps in the road. I regreased the rear sway bar bushings with synthetic grease and used silicon spray on the other bushings on the parts i mentioned. Sounds like a new car again!
2005 Camry "LE"
TL HID Retrofit | OEM Fogs | SE Bumper | SE Grill | Factory Spoiler | Kosei K1 TS 18x7.5 | BC Racing Coilovers
TRD [RSB | Strut Tower Brace | Exhaust] || Rear Drum to Disc Swap
LE05 is offline   Reply With Quote
Old 01-04-2009, 06:51 PM   #3 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Might have to take out the swaybar and lube the insides of the bushings themselves.
It is possible for sway bar end links to be out, but are the rubber coverings cracked or leaking or anything? Also, check to see how much play each end link has, if it's abnormally loose or if it is cracked or ripped, then you would need to replace them.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 01-05-2009, 09:21 AM   #4 (permalink)
MrSo0h0o's Avatar
I will try and take a picture of how my bushings look when I get home from work... How much does it usually cost to replace the bushings?
