darksparkz - here we go camera talk again! lols, yeah, i think there's sensor dust on the e51 too. not bad for a shitty 2mp cam. (i forgot my slr at home)
- for the +30 offset 9.5 rear, there's maybe a couple mm clearance to the strut, maybe close to finger's width.
ebum - yeah they poke out a bit, but just enough. i tried adding a 5mil spacer on the rear, lols talk about poke on a FWD!!!
anabolik - thanks dude
jan - the tires in the shop i tried were 245/35/20. too fat. the rear looks good actually with the 245/35/20 but that would mean i have to raise my car a lot more than i need to clear if i had 225/35/20. there's no way 245 on the 9.5 +35 will clear the fender in the front. you can't camber it too much because it will hit the strut, but if you camber it and add spacers, then you might as well not add camber and remove the spacers.
GTR: it was designed for the track...lol a railroad track!
** the tires i tested were kumho (cum-hoe) ecsta spt and they ran large and not true to size. 245/35/20 on a 9.5 DID NOT have a stretch at all. next tires to test will be yokohama S.drives because they run true to size and is stretch friendly.
