DIY cooling fan for stereo question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2009, 10:35 AM   #1 (permalink)
View nelsonrx's Photo Gallery
I'd like to add a cooling fan (CPU type) to my aftermarket navigation unit. I'm thinking I could tap into the ignition triggered positive cable as well as the negative cable that go into my stereo. I'm not great with calculating electrical loads, etc. Does anyone know of an easy to do this? I'm trying to get it so that the fan turns on/off with the unit....
nelsonrx is offline   Reply With Quote
Old 01-09-2009, 10:37 AM   #2 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
why, any problems with the unit?
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 01-09-2009, 10:43 AM   #3 (permalink)
Gameroom cash: $203160
View CamrySExxx's Photo Gallery
CamrySExxx is offline   Reply With Quote
Old 01-09-2009, 10:57 AM   #4 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
computer type 12VDC cooling fans draw a minimum amount of power. (like 0.3 Amps) look into a hard drive cooler and see the electrical ratings there.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-09-2009, 11:00 AM   #5 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
How r u planning to do this circulation?
workerant is online now   Reply With Quote
Old 01-09-2009, 11:06 AM   #6 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $304005
View MrSo0h0o's Photo Gallery
x2... and will you be able to control it? In the summer, yes I know my unit gets very hot.. But during the cold winter, it takes a while for it to warm up.
Maybe figure out a way to tie it into the HVAC system, since the vents are right there..
MrSo0h0o is offline   Reply With Quote
Old 01-09-2009, 11:25 AM   #7 (permalink)
Take it easy... :-)
Tobeit's Avatar
..if it is not broken, don't mess with it. So, does the unit shut off when overheating or what? If so, send it back to the mfg as units should be designed to work w/o an extra fan.
Old 01-09-2009, 12:19 PM   #8 (permalink)
Electronic works OK in cold weather. But heat can melt things.
The best way for this is see if the receiver have a power antenna connector. The one that when you turn on the receiver it extend the antenna. I'm not sure if this connector turn off the power once the antenna is fully extend.
Old 01-09-2009, 12:26 PM   #9 (permalink)
The unit works fine so far, but if you look at every brand name manufacturer of head units out there (i.e. Pioneer, JVC, etc) they all come with a built in fan. Its just a known fact that cooled processors work longer and more efficiently than overheated ones. I'd like to do this if its an easy fix. TTM77- thanks for the great idea. I'll have to check that cable out....
Old 01-09-2009, 12:34 PM   #10 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
A CPU may become unstable if it's too hot or if you give it insufficient voltage. If you give too much voltage then it will overheat and also may fry depending on the amount of voltage.
HOWEVER, if a CPU is within operating temperature (let's suppose between -20 and +70 Celsius degrees) then it will work EXACTLY the same at ANY of the temperatures in that range. It will not work any more or any less efficiently.
I just thought I'd throw that in so that people don't have misconceptions. However, keeping the CPU cooler WILL extend its overall lifespan.
If you cannot attach a computer fan somewhere, consider installing a small chipset or video card RAM heatsink on the CPU and/or chipset of your device inside. Use either Arctic Silver 5 or Arctic Cooling MX-2 thermal compound to bond the thing. Use about 1/4 of a pea size drop or even less. The RAM heatsinks usually come pre-applied with 3M thermal tape.
Even without a fan, a passive chipset heatsink will dissipate heat better due to the increased surface area over which to spread the heat out.
You can find all of these parts at NCIX (they have a US and Canadian site) or Newegg (they have a US and Canadian site).
If you require any assistance please feel free to ask me. I am an expert in computer hardware.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 01-09-2009, 12:46 PM   #11 (permalink)
Take it easy... :-)
Tobeit's Avatar
...let me guess, you bought a "cheap" unit from a discount store like e-bay, found "made in China" on it and now think it's not designed right as it gets pretty hot...? Bogus. Go to your TV and touch some of the components their. Btw, their are different grades of electronic chips/components re allowable temp range. Commercial applications have 140C ratings (normally), lower grade is 120C, military grades are higher etc...70C is just the max spec on the operating temp but not the max spec on the actual component surface temp.
Again, if not broken don't touch it and in particular if you are not an expert. Attaching a heatsink like described to your unit is complicated as you need to take the unit apart and put the heatsink directly on the chip you think is in most danger...do you know wich it is? Also voids your warranty...
Old 01-09-2009, 01:08 PM   #12 (permalink)
LoudCamry's Avatar
Gameroom cash: $229327
View LoudCamry's Photo Gallery
adding a fan can be annoying you will hear the fan spinning.
LoudCamry is offline   Reply With Quote
Old 01-09-2009, 01:11 PM   #13 (permalink)
the unit would be designed to run in hot/cold temps. If you bought a good brand unit than it will last a while...no point of adding a fan
