Maintenance Required Sign Flashing - Toyota Nation Forum : Toyota Car and Truck Forums
Closed Thread
Old 01-11-2009, 03:04 AM   #1 (permalink)
View commissary's Photo Gallery
Sooooo, I turned on my car today and the maintenance required sign was flashing for about 30-45 seconds, then went away. I thought nothing of it, but it continued on through out the day every time I started up the car.
Should I go check it out or is this a common thing that will go away?
commissary is offline
Old 01-11-2009, 03:51 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550825
When is the last time you had your car serviced? I think it comes on 4500 miles or so after the last time it was reset. It is a reminder, not an indication of malfunction.
Do a search or look in your manual and you will find the procedure to reset it.
2007 Camry 2.4L 5M
touringcamry is offline
Old 01-11-2009, 03:58 AM   #3 (permalink)
GO RED SOX!
Dana_15's Avatar
Gameroom cash: $220606
iTrader Score: 9 reviews
View Dana_15's Photo Gallery
Change oil if necessary, then reset.
If the procedure is the same as the Tundra:
To reset your maintenance reminder system (even if the light hasn’t come on yet), you’ll need to turn your key to on (but don’t start!) and make sure your odometer is on TRIP A. Then key off. Press and hold the Odometer/Trip button. While holding down on the button, key the ignition to on (Don’t start the engine!) The display panel will count down from “------“ to “-“Continue pressing the button until the Trip A is displayed. After this step, you are done.
Dana_15 is offline
Old 01-11-2009, 04:36 AM   #4 (permalink)
I have an '09 Camry LE. Its at about 4550 miles right now. I changed the oil at around 3000 miles.
Old 01-11-2009, 07:35 AM   #5 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $462074
View BlackCamSe's Photo Gallery
i cant wait to see Njeralds reply.... Look in your manual and it will tell you how to reset the light.
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now
Old 01-11-2009, 11:18 AM   #6 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Just another worthless thread to clog up any useful Search effort....
njerald is offline
Closed Thread
