the oem filter for the camry comes in both the F1 and F2 guise...the F1 is a taller filter, and thus holds more oil, and thats the one that i use...theyre what is reccomended by toyota for the I4 camry, but since the F1 and F2 have the same base fitament, theyre interchangable so you could use either one on a camry/corolla/anything with a 4cyl....its your choice to use whichever one you like...just request the tall F1 filter next time...not all dealerships stock both, so be alert and aware of your dealership's stock
i switched to mobil 1 at 39k, and no issues at all...the car does seep a tiny bit of oil from the valve cover, but thats because the less viscous composition of the synthetic oil...it may cause a tiny bit of seepage, but no major leaks...my car gets the full return of 4.2qts every 3-3.5k, and im now at 70k
The "Executive Sedan"
