Check engine light, bad gas? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2009, 01:56 AM   #1 (permalink)
View ylen13's Photo Gallery
I filled up my 2008 camry se v6 with 89(yes i know manual says 87 but i it don't hurt to put 89). About 30 min after that i turned off car and after coming back after about 45 min check engine was on. Gas cap is tightened correctly, could this problem be caused by bad gas?
I only have 10k on my car.
TIA
ylen13 is offline   Reply With Quote
Old 01-21-2009, 02:01 AM   #2 (permalink)
씨발
PRINCESS PEACH's Avatar
Gameroom cash: $209800
iTrader Score: 22 reviews
View PRINCESS PEACH's Photo Gallery
no. your engine light did not come on because of your gas.
Do you need car parts?
AdvanceSpeedShop
I Am Parting Out: click!
Questions about your own stupidity?: PM NJERALD
PRINCESS PEACH is offline   Reply With Quote
Old 01-21-2009, 02:12 AM   #3 (permalink)
Well thanks for reply, have appointment with dealer set for Thursday hopefully nothing major.
Old 01-21-2009, 02:14 AM   #4 (permalink)
씨발
you can try resetting your car.. unplug your battery for a couple minutes... it doesn't hurt to try
AdvanceSpeedShop
Old 01-21-2009, 04:33 PM   #5 (permalink)
Tried to do "soft" power reset. Light back on 5 min after i started driving. I am hopping it's simple as gas cap being bad, as car drives fine.
Old 01-21-2009, 05:05 PM   #6 (permalink)
View camlex's Photo Gallery
get code from autozone.
camlex is offline   Reply With Quote
Old 01-22-2009, 03:39 PM   #7 (permalink)
Dealer ordered wire harness and some gaskets. Forgot to ask exactly what the problem is but was told it's safe to drive. The error code is p-2240, anyone know what error code means?
Old 01-22-2009, 04:37 PM   #8 (permalink)
The Connoisseur
CharmCityES's Avatar
P2240
Oxygen (A/F) Sensor Pumping Current Circuit / Open (Bank 2 Sensor 1)
pulled from my toyota techstream.
The "Executive Sedan"
Old 01-22-2009, 05:37 PM   #9 (permalink)
Originally Posted by CorCamrySE View Post
P2240
Thank you for posting that, how common is this problem? I only got 10k
Old 01-22-2009, 06:21 PM   #10 (permalink)
The Connoisseur
my mom had the same issue on her 2007 solara sport V6 convertable at 12k....replaced the sensor and it was fine after that
could be a manufacturing defect in the sensor, could be that you used cheap gas...my mom was using cheap gas, so now she uses brand name gasoline and has no issues at 19k
Old 01-22-2009, 09:35 PM   #11 (permalink)
View MrObvious's Photo Gallery
All gas is the same pretty much nowadays. That's what Tom and Ray Magliozzi (spelling) say.
MrObvious is offline   Reply With Quote
