shoould be under the certified warranty....ive seen a few 2007 V6 camrys with this issue...its the same issue as the 2005-2007 avalons, where the rubber VVTi oil line springs a pinhole, and leaks a massive amount of oil....i work at a dealer in MD and i know the part is majorly backordered in our area (central atlantic toyota), so weve had a few of these camrys sitting for almost a month waiting on parts
id raise hell...there is a TSB out on this issue, and warranty should definitly cover it as it is an engine componet that is not a maintenence/wear item like a belt or filter or something
call toyota corporate if the dealer wont cooperate...the least they can do is reimburse you for the cost of repairs
The "Executive Sedan"
