Camry takes forever to heat up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2009, 12:03 PM   #1 (permalink)
Registered User
View qprint's Photo Gallery
15 deg F here and I let car idle for a minute and then start driving it at about 50 mph and after 10 min, car still has not reached operating temperature. I flushed and replaced coolant[50/50] 2 years ago myself. It tales 20 min to get home from work and as I drive 1/2 the distance, I start to get heated up in the car and temp guage gets to Normal
Am i looking at the ECT sensor being faulty?
Also i smell fuel after the car starts and idles. running Rich ?
qprint is offline   Reply With Quote
Old 01-27-2009, 12:13 PM   #2 (permalink)
ASE Master Technician
JSM1284's Avatar
Gameroom cash: $186325
View JSM1284's Photo Gallery
Your thermostat could be stuck open.
Your source for Gen6 TSX Retro's (PM for details)
2005 Lexus ES330
2007 Camry SE V-6 Titanium(SOLD)
Moonroof, Navi, Sport Leather, Floor Mats, Phillips 4300k HID, 15% Tint, Silverstar Turn signals
“My friends call me ‘The Cane.’ Even before I messed up my leg.” ~Dr. Gregory house
JSM1284 is offline   Reply With Quote
Old 01-27-2009, 12:14 PM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Another Comedy Central thread...
Old 01-27-2009, 12:16 PM   #4 (permalink)
View hendrix8989's Photo Gallery
3 blocks going 20 miles an hour she is warmed up
hendrix8989 is offline   Reply With Quote
Old 01-27-2009, 12:17 PM   #5 (permalink)
hazer00's Avatar
View hazer00's Photo Gallery
There are a couple issues that you could be having. The first option and the cheapest, would be to have the thermostat replaced. If that does not fix the problem; have your coolant system pressure to tested to see if there are any leaks. Also are you running factory coolant or aftermarket green coolant. You may or may not need to change it again depending on the service interval. The factory recommends Toyota S-LLC(Super Long Life Coolant; its pink in color and lasts for 100k)
As for your smelling fuel issue, are you smelling it as if there is a fuel leak, or do you smell rich exhaust fumes? 04 Camrys are not known for fuel leaks. Especially not the V6. Do you have a CEL?(Check Engine Light) 04 Camrys have an wonderful evap system and if you are running rich, your car would definitley throw a code.
ASE CERTIFIED, TOYOTA TECHNICIAN
If you have questions, just ask!
hazer00 is offline   Reply With Quote
Old 01-27-2009, 01:48 PM   #6 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Another option is to get a remote starter.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 01-27-2009, 02:06 PM   #7 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Gameroom cash: $149932
View Yazovets's Photo Gallery
That is not a solution at all, but a pollution contributor.
2008 Camry Hybrid | Magnetic Grey on Grey Leather | Bi-Xenon H1 4300K Retrofit | Italian Hertz Sound System (dash 4" EM 100, front 6.5" ECX 165, rear 6" x 9" ECX 690, 10" ES 250D sub in custom trunk enclosure, HDP5 5-channel amp, 1320W total power) | 4-sensor Rear Parking System | 20% Metallic Tint | Weathertech Floorliners | 17" ASA AR1 Rims | Toyo Garit KX (winter) | Toyo Versado LX II (summer)
Yazovets is offline   Reply With Quote
Old 01-27-2009, 02:12 PM   #8 (permalink)
Gameroom cash: $303755
He is located in Ontario Canada. It's a bit colder there this time of year than your area.
Mike
Old 01-27-2009, 02:51 PM   #9 (permalink)
2008 Camry Hybrid
Yazovets's Avatar
Mike
I'm in Ontario as well and once you've gone around a few blocks, the car is ready despite the cold weather.
Old 01-27-2009, 03:20 PM   #10 (permalink)
View billwot's Photo Gallery
Thermostat!
billwot is offline   Reply With Quote
Old 01-27-2009, 03:23 PM   #11 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
Even cheaper eco-friendly solution... buy a microfiber blanket... they're soft cozy, and gets the job done... you can pick it up at your local wal-mart
My Partial Partout!!!
Photo Album
Old 01-27-2009, 04:17 PM   #12 (permalink)
Registered User
Thermostat never replaced. Got 120,000 KM. Replace coolant at 80,000 with Toyota Red mixed with Distiller water. I smell rich exhaust fumes only after starting it and no smell as it warms up. No CEL
Old 01-27-2009, 04:44 PM   #13 (permalink)
verlaryder's Avatar
View verlaryder's Photo Gallery
Stuck open thermostat = slow warmup AND a rich fuel mixture.
Use a Toyota thermostat and Toyota thermostat gasket to avoid more potential trouble
verlaryder is offline   Reply With Quote
Old 01-28-2009, 08:21 AM   #14 (permalink)
Registered User
drove 5 minutes , distance of 3 miles(U.S.) at 40 MPH with outside temp 20 deg F for cars temp to reach Normal Operating Temperature.
Is this normal ?
Old 01-28-2009, 01:48 PM   #15 (permalink)
View MrObvious's Photo Gallery
Is this normal ?
That's about what it is for my i4. The higher RPMs help heat it up (I mean the revs needed to keep a speed, not acceleration) faster I think. Try doing 20 and it may never heat up.
MrObvious is offline   Reply With Quote
