Sunroof Wind Deflector - Rattle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2009, 11:53 AM   #1 (permalink)
View holimont's Photo Gallery
On my 08 LE the wind deflector rattles when the sunroof is closed. I stopped by the dealer today asking if there was a quick fix for this problem. The Service Writer didn't know of one. He said they would be glad to work on it, give me a loaner, etc. But he confirmed what I saw in the service manual - to gain access to the sunroof the headliner must be removed. And that means disassembling the cabin interior, to include removing the seats. I'm afraid the cure might be worse than the disease.
I'm wondering if someone has found a simpler solution. Stick-on pads, or some such.
holimont is offline   Reply With Quote
Old 01-28-2009, 12:36 PM   #2 (permalink)
Take it easy... :-)
Tobeit's Avatar
Gameroom cash: $119100
View Tobeit's Photo Gallery
have the same issue, did not find an easy fix yet (pads etc).
"Just for Fun" http://www.cardomain.com/ride/2973919
Tobeit is offline   Reply With Quote
Old 12-16-2010, 02:50 PM   #3 (permalink)
***lurking***
08TRDOFFROAD's Avatar
Gameroom cash: $428707
View 08TRDOFFROAD's Photo Gallery
When you guys refer to the deflector, are you referring to the black piece that pops up in the front when the roof is opened?
My wife's Camry has a rattle in the front side of the sun roof and it seems to be coming from the metal bar/piece below the black defector that pops up. I haven't really had a chance to tear into it, but I was wondering if this is the same rattle you guys are experiencing and whether or not you have discovered a quick fix for the issue.
08TRDOFFROAD is offline   Reply With Quote
Old 12-16-2010, 08:28 PM   #4 (permalink)
View littleslim1474's Photo Gallery
If your talking about a pooping noise coming form the front sunroof area while going over uneven roads its probably not the deflector. There is a TSB for the issue i can get you the number for it. There is a flat of sheet metal by the sunroof that forms a pressure point causing it to pop. The headliner does need to be dropped to apply some sound deafening material under that pressure point. The Whole sunroof will have to come out too. Hope that helps. Its about a 1-2 hour job if the tech know what hes doing. Let me know if you need the tsb number
littleslim1474 is offline   Reply With Quote
Old 06-27-2011, 08:01 PM   #5 (permalink)
View strill19's Photo Gallery
I have this problem with my 2010 se v6 12k on it. It sounds like its above the visors and also in rear near the grab handles on headliner. Most noticeable on uneven surfaces like pulling in driveway. If you have the TSB that would be great.
strill19 is offline   Reply With Quote
