Fender ding: DIY or professional? Looking for opinions - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-01-2009, 09:38 AM   #1 (permalink)
View wineyarders's Photo Gallery
Greetings All,
I have a decent ding in the left fender and I'm debating whether to spend the $500 to get it professionally done or to just do it myself. Unfortunately I can't post pics, but it looks like a good size rock bounced off it. There's a minor dent and all of the paint was chipped off. The damage covers about the size of a half dollar coin. If I repair, I'll need to try and pop the dent, fill, and paint. I don't need it to look new, but it's an '07 so I don't want it to look horrible either. I would need to brush on touch up paint and I'm not sure brushing as opposed to spraying will work. Any thoughts on whether the end result will be decent would be appreciated, thanks,
Ryan
wineyarders is offline   Reply With Quote
Old 02-01-2009, 10:21 AM   #2 (permalink)
2009 Camry SE I4 MGM
glenn14's Avatar
Gameroom cash: $337725
View glenn14's Photo Gallery
Originally Posted by wineyarders View Post
Greetings All,
Ryan
Unless you are sure of your skills, you would need to pop out the dent, use filler then sand prime, paint and clearcoat. With spray paint not brush, then buff once everything hardens. Otherwise I would have a body shop fix it.
But I am anal when it comes to these things. Just mhho.
Glenn
2009 Camry SE MODS:
Blacked Out Headlights with MDX D2S Retrofit,TSX-R Clear Lens, 85122+D2S Bulbs, G2 Red Painted Calipers, W.T.Floor Liners, Rosen Navi. GEN6.5 Chrome Wheels, XD Digital 35 watt ballasts, H11 Wire Harness, Megan fstb.
glenn14 is offline   Reply With Quote
Old 02-01-2009, 04:52 PM   #3 (permalink)
Not-So-New TN User
Netforcer's Avatar
Gameroom cash: $225700
paintless dent repair... shouldn't cost more than $60... then use touch-up paint... and get it done soon before it starts rusting
My Partial Partout!!!
Photo Album
Old 02-01-2009, 06:27 PM   #4 (permalink)
Thanks for the replies. I figured out how this forum recommends to post pics, here is a link to a photo of the damage
Unfortunately, it's been a couple weeks so it's already started to rust.
Glenn, regarding spray vs brush, is the brush just too coarse? I want to stay away from the aerosol paints since I don't think they'll match factory color. I don't own a sprayer.
Thanks again,
Ryan
Old 02-01-2009, 06:29 PM   #5 (permalink)
View 1956kiteboarder's Photo Gallery
Wow what a bummer! That sucks. Since its such a new car I would have it professionally painted, they would have to due the whole fender, if they fade it in it will be more noticeable.
1956kiteboarder is offline   Reply With Quote
Old 02-01-2009, 06:42 PM   #6 (permalink)
"Circle of trust"
View catric69's Photo Gallery
I have to say that does not look like a rock hit it. It looks like something gashed it instead. Did you hit someone with the front of your car? Or vice versa?
catric69 is offline   Reply With Quote
Old 02-01-2009, 06:43 PM   #7 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
That's a pretty big area for touch up paint in my opinion, I've tried touch up paint, and failed, lol.
But when I use spray cans, they do work quite well and match nicely.
But if you want the perfect finish, then do it professionally of course.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 02-01-2009, 07:09 PM   #8 (permalink)
glenn14's Avatar
Thanks again,
Ryan
That is a pretty big gash and rust spot much to big for a brush. I would have a shop do it for you. That area has to be taken down to bare metel, filled primed, sanded painted then clearcoated, and as somebody stated above, the whole fender may need to be painted so the color is even......
Glenn
2009 Camry SE MODS:
Old 02-02-2009, 06:42 PM   #9 (permalink)
blending
Sparkz,
When you used the spray, did you just focus on the damaged area or did you need to blend into the surrounding area? I've heard the matching spray often doesn't match the factory paint that well. I don't need it to look new, but I don't want it to stand out when you walk by (or someone else walks by). And I don't mind fading a tiny bit but have no interest in getting into this if the paint is going to need a lot of blending. Thanks for the advice,
Ryan
Old 02-02-2009, 06:56 PM   #10 (permalink)
Not-So-New TN User
Netforcer's Avatar
wowser... i don't even want to think about the sound that would have made... you def need to get it professionally done
Photo Album
Old 02-02-2009, 07:44 PM   #11 (permalink)
View GeorgiaHybrid's Photo Gallery
If you have never blended a new repair into existing paint, do yourself a favor and get a pro to do the work. You will never be happy with the result otherwise and you will save yourself a lot of pain and suffering.
GeorgiaHybrid is offline   Reply With Quote
Old 02-03-2009, 04:19 AM   #12 (permalink)
Rapid Roy's Avatar
View Rapid Roy's Photo Gallery
I say go for it if you have the time and paitence. Do lots of research on line first so you know what to do. You can buy factory matching paint in aerosol cans on line. Start by searching this forum for touch up paint. There have been lots of good threads about doing your own body work.
Rapid Roy is offline   Reply With Quote
Old 02-04-2009, 08:01 PM   #13 (permalink)
Rapid Boy, I've been trying to do research on how much I should expect to need to blend to get decent results. I know the shop said they would need to blend the whole panel and part of the hood to get it right. I don't need it perfect, but I don't want it stand out. I've tried searching the forum and the net with little success. Since this is new to me I'm having a tough time finding those resources. Any direction would greatly be appreciated, thanks,
Ryan
Old 02-04-2009, 08:12 PM   #14 (permalink)
Go to more body shops, spraying part of the hood , tells me they do not know there craft. You paint the whole fender and the entire hood or just the fender.
I would paint the whole fender and leave the hood alone, the sun will take care of the fade in.
the fade in job on the hood will become ugly in a few months.
I know from experience.
Old 02-04-2009, 08:31 PM   #15 (permalink)
glenn14's Avatar
^^^ I agree 100% with what kiteboarder said......
Glenn
2009 Camry SE MODS:
