First time sub installation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2009, 03:06 PM   #1 (permalink)
View Pandamanda's Photo Gallery
I've decided to add a little bass to my life. I picked up a couple of Kickerz subs and an amp the other day but the more I think about it, the less willing I am to trust someone else with my baby. Can anyone direct me to a previous post (I've searched) that gives step-by-step instructions? Or maybe share some knowledge? I have a 2002 Camry LE with the stock head unit. Let me know if there's any info I left out that's needed to help. Thanks!
Pandamanda is offline   Reply With Quote
Old 02-02-2009, 04:18 PM   #2 (permalink)
Gameroom cash: $201860
View CamrySExxx's Photo Gallery
This has been covered many times but maybe i'll try to help you out.
First of all you will need a line output converter since the stock head unit does not have any pre-out puts for the rca's. The line out converter connects to two speaker lines that come from the head unit. People usually hook it up to the two rear speaker cables. This uses the signal from the headunit and converts it so you can use that signal using rca wires for your amp.
The next thing you need to do is to run a power wire from your +ve battery to the back of your trunk or where ever you will be installing the amplifier. This might be a bit more challenging getting the power wire from the engine back to the back but its possible. Once that is done you will need to hook up a ground cable for your amp which is pretty easy. Just attach it to any part of the chassis and make sure to scrap any paint off. Also make sure you use the same gauge wiring for the ground as you did for your power.
So far this has your, rca's, +ve power, -ve ground covered and all you need is a remote wire. Since you are just using your stock head unit it would be easier to run a remote wire from a fuse underneath the driver side dash rather than taking apart your dash. You would want to look for a accessory fuse so the amp will turn on when you have your key in either the acc. or on. position. Search and you will find which fuse to use, or use a handy +12v test light and find a fuse for your self.
Once your amp is hooked up, connect it to your subs. Properly adjust the gains and your set.
p.s now that i some what helped you. Please do me a favour and DO NOT blast your subs are like mid night while in a residential area. Your whole block will hate you and your system will probably get stolen quickly.
CamrySExxx is offline   Reply With Quote
Old 02-02-2009, 04:45 PM   #3 (permalink)
Sorry, when I searched for a step-by-step, I only found posts regarding specific questions about the installation.
Old 02-02-2009, 11:44 PM   #4 (permalink)
Ah gotcha, well hope i helped you. If you have any questions i;ll try my best to answer it .
Old 02-02-2009, 11:53 PM   #5 (permalink)
View RoseMobile's Photo Gallery
nice write up glad to see ppl help rather than yell "use the search function"..
RoseMobile is offline   Reply With Quote
Old 02-03-2009, 12:00 AM   #6 (permalink)
bigloubumpin's Avatar
Gameroom cash: $150645
View bigloubumpin's Photo Gallery
Buy the PAC Trunk LOC,all connections can be done via the trunk.
bigloubumpin is offline   Reply With Quote
Old 02-03-2009, 03:38 AM   #7 (permalink)
View MrObvious's Photo Gallery
Agreed. I hope I can find this thread when I put 10s or 12s in.
MrObvious is offline   Reply With Quote
Old 02-03-2009, 08:05 AM   #8 (permalink)
Thanks for the help!!
