ABS, Trac, and VSC lights - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-02-2009, 05:57 PM   #1 (permalink)
View nick13531's Photo Gallery
Unhappy ABS, Trac, and VSC lights
I recently bought a new 2009 Toyota Camry in December. This past couple of weeks the ABS, TRAC, AND VSC lights all came on. I took it to the dealership and they checked for an open circuit in the brake light switch.So, I left and before I got home the lights came on again. So, then they had to call Toyota technical department and told them if they didnt find any faults just replace the ABS Acuator...so they replaced the abs actuator and brake fluid and all that. So I picked it up this last Saturday after they changed it and before I got home the lights came on again...so I took to the dealership today and they said they were going to have to keep it until a part comes in. They said they think they found the fix for it....they ordered a new brake light switch...can this really cause all of these lights to come on? The car only has 550 miles on it.
nick13531 is offline   Reply With Quote
Old 02-02-2009, 06:36 PM   #2 (permalink)
View toyomoho's Photo Gallery
A common fault can cause all the systems to turn off.
Old 02-02-2009, 07:39 PM   #3 (permalink)
'07 XLE
Gameroom cash: $283530
View njerald's Photo Gallery
Gen6
Depends on what DTC was set.
They sound like they are guessing but that's your dealer for you....
Old 02-02-2009, 08:26 PM   #4 (permalink)
View sniper34's Photo Gallery
Dealers replace, they don't diagnose too deeply. It's easier to replace till they get it right IMHO. Brake lite switch? Can't see how. Computer, yes.
sniper34 is offline   Reply With Quote
Old 02-02-2009, 08:46 PM   #5 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $359160
iTrader Score: 13 reviews
I would have said abs actuator as well, but they replaced that already, right?
I can also see ecu.
but it's most likely an abs related issue, since all the other systems depend on the abs braking system
HaHa
Old 02-03-2009, 11:20 AM   #6 (permalink)
View rondia's Photo Gallery
Toyomoho is correct. When your check engine light comes on it also turns on ABS and Trac and VSC light. Need to run codes and diag from there. Example-in my case it was the air fuel sensor.
rondia is offline   Reply With Quote
Old 02-03-2009, 12:58 PM   #7 (permalink)
View MrObvious's Photo Gallery
You can run to Autozone and it is completely free.
MrObvious is offline   Reply With Quote
The Following User Says Thank You to MrObvious For This Useful Post:
Jonasson (07-22-2011)
Old 02-03-2009, 04:06 PM   #8 (permalink)
On my receipt it says code c1249 set, open in stop light circuit.
Old 02-03-2009, 07:11 PM   #9 (permalink)
'07 XLE
Gen6
So why the Hell start a new thread about it?????????????
Old 02-03-2009, 07:17 PM   #10 (permalink)
See if a brake lite is out.
Old 02-21-2010, 01:02 PM   #11 (permalink)
Gen6
It turned out to be the brake light switch. If they would have just changed the simple little switch out in the first place instead of replacing the abs actuator first, then things would have been taken care of in one visit instead of 4. Oh well. It's fixed now
Old 02-21-2010, 01:14 PM   #12 (permalink)
LOV
268 HP OWNER
LOV's Avatar
View LOV's Photo Gallery
^ really? same happened to me, and they changed some kind of sensor and it was fixed.
2007 Camry SE V6 , MGM
LOV is offline   Reply With Quote
Old 07-11-2011, 03:17 PM   #13 (permalink)
bawazir_chicago's Avatar
View bawazir_chicago's Photo Gallery
Question
Hi sir,
I have the same issue as you having, can you please let me know where is the location of the brake light switch?
thank you,,
It's hard to be humble when you're from Chicago.
link:http://www.cardomain.com/ride/3820102
bawazir_chicago is offline   Reply With Quote
