harsh coilover ride... - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2009, 12:14 PM   #16 (permalink)
v6secamry's Avatar
iTrader Score: 12 reviews
View v6secamry's Photo Gallery
Originally Posted by LoudCamry View Post
hey Mr. V6secamry, what year and model will your tein coiloverr work with??? where you got them from???
I got them from tein directly, as they were custom made for my camry.
edit:
Just as Phatroyle stated, all coilovers will be harsher than stock no matter what. But if you can go lower in spring rates or lessen your preload(assuming you put too much preload) the ride comfort will not be so bad.
v6secamry is offline   Reply With Quote
Old 02-04-2009, 12:30 PM   #17 (permalink)
"Everyone Lies"
Dna_splice's Avatar
View Dna_splice's Photo Gallery
I'm still crying...
'03 SE i4 <3
"Si vis amari ama"[If you want to be loved, love.]
Dna_splice is offline   Reply With Quote
Old 02-04-2009, 04:56 PM   #18 (permalink)
2007 CAMRY XLE V6
View azntuner8's Photo Gallery
im not sure if my buddy and i preloaded it, we just ajusted the two spindels to where i wanted it and just messed with it until we got it even and how i wanted it...ill ask my buddy if we preloaded it but im not really sure what that is lol
Originally Posted by Eye8Pussies View Post
did you preload the springs? what are your spring rates?
[/SIGPIC][/SIGPIC]20"TIS 12s,NT555s,MEGAN COILS,6kHIDS,200ampALTERNATOR,2SHUREKIN BATTERIES,PIONEER AVH-P4200,VIZUALOGIC TVS,JL 10W7s,1000/1v2,300/4v2,FOCAL165 K2Ps,E&G GRILL,WOODGRAIN STEERING WHEEL,CUSTOM TWO TONE SUEDE INTERIOR,FUTURE MODS-BAGS,SUICIDE SHAVED DOORS,WHEELS N PAINT JOB
azntuner8 is offline   Reply With Quote
Old 02-04-2009, 05:01 PM   #19 (permalink)
2007 CAMRY XLE V6
yea i know lol i probley will go airbags, but i am gunna try messing with my coilovers first maybe raise it an inch or so and lessen the dampening
Originally Posted by CorCamrySE View Post
the car looks great!
as for the ride, id lessen the dampening
if that doesnt work, go full VIP status and get airbags
Old 02-04-2009, 05:02 PM   #20 (permalink)
2007 CAMRY XLE V6
haha yea ok ill think about
Originally Posted by Netforcer View Post
yea, take'em off and swap them with my TRD springs
Old 02-04-2009, 05:05 PM   #21 (permalink)
2007 CAMRY XLE V6
yeah ill try that but has anyone heard of changing the bushing?someone told me that would make it softer?
Originally Posted by v6secamry View Post
what are your spring rates? if they are somewhere 7-10 kg in front, and 4kg to 7 kg in rear. I would recommend you get lower spring rates. For example, tein ss coilovers come with 6kg front and 3kg rear imo best for daily driven and occasional track.
Pre-load refers to tension on the springs while there is no weight on the spring(car in the air)
The Megans allows two ways of ride height adjustment.
1.) You can adjust the lower spring seat up or down. Adjusting here changes where the strut shaft sits, so adjusting ride height this way changes suspension travel and changes spring preload. With the Megans, you do not want too much preload, too much preload= harsher ride. You want the spring to be snug but not compress because the megans will allow to you further adjust the height by using #2 below
2.) You can adjust the bottom ring which controls where the bracket sits on the strut. Adjusting with the lower mount simply moves the whole strut assembly relative to the chassis without changing suspension travel or changing spring preload.
darksparkz: I know you are interested in the tein ss. With the tein super street, you adjust ride height using #1.
hope this helps
edit: here are some pics of my ksports
the ksport adjustability is the same as the megans coilovers
here are my tein super street
Old 02-04-2009, 06:21 PM   #22 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Actually, I was just on Tein's website and they quoted:
Full Length Adjustable -
Vehicle ride height and spring pre-load can be adjusted independently. Ride height is adjustable in two ways: a. adjustable shock length, and b. adjustable spring seat.
a. The lower mounting bracket can be adjusted, thus changing the overall length of the shock, and therefore altering the vehicle's ride height. This also allows the user to determine suspension travel and droop.
b. The adjustable spring seat allows for independent adjustment of spring pre-load without affecting vehicle ride height.
Aluminum spring seats are utilized to reduce ceasing of spring seat to threaded body, and for improved durability.
That's for the Tein SS, does that mean there actually is a lower part to adjust for height?
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 02-04-2009, 06:36 PM   #23 (permalink)
2007 CAMRY XLE V6
well i think with my megans one spinldle is to adjust height and the other spindle is to adjust the spring rate...
Old 02-04-2009, 08:56 PM   #24 (permalink)
v6secamry's Avatar
actually what you just copy and paste is for the tein flex and the higher end track model not the super street
http://www.tein.com/products/super_street.html
click on the Ride Height
Adj. more
and it will state
Ride Height Adjustable -
Vehicle ride height adjustable via a threaded shock body and adjustable spring seat. The threaded sleeve is welded to the actual shock body and then Zinc coated for added protection. TEIN engineers have performed vigorous testing to ensure the best possible position and range of the spring seat to ensure the most adjustability. Aluminum spring seats are utilized to reduce ceasing of spring seat to threaded body, and for improved durability.
ride height adjustable is different from Full Length Adjustable
ride height adjustable is method 1 and full length adjustable is method 2 in my previous post
edit:darksparkz i can see where you got the full height adjustable description because it is listed right below the ride height adjustable description
Old 02-04-2009, 09:27 PM   #25 (permalink)
2GR FTW
darksparkz's Avatar
Yeah, it was right below it, didn't look on the one above I guess, whoops. Makes more sense now.
