thanx for the help! :) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-04-2009, 04:05 PM   #1 (permalink)
icqboy51's Avatar
View icqboy51's Photo Gallery
thanx guys! fixed the blown fuse!
icqboy51 is offline   Reply With Quote
Old 02-04-2009, 04:15 PM   #2 (permalink)
2007 Camry SE V6
Gameroom cash: $128590
View thrawnis's Photo Gallery
I'm just taking a guess at this point, but maybe the fuse blew out? Check the fuse box.
My Update Thread: http://www.toyotanation.com/forum/sh...d.php?t=319520
2007 Camry V6 SE | Blue Ribbon Metallic | UR Strut/Sway Bar | K&N SRI | Magnaflow mufflers | H&R Springs | TSW Cadwell 19x8 Wheels | 6000k HIDs | Reus Custom Sound System | Tinted Headlights | Smoked LED Taillights | More
thrawnis is offline   Reply With Quote
Old 02-04-2009, 04:17 PM   #3 (permalink)
It's Soo Hoo like Yoo Hoo
MrSo0h0o's Avatar
Gameroom cash: $283505
View MrSo0h0o's Photo Gallery
x2.. did you have your lights in the ON position when trying to replace them? your harnesses seem fine(not melted) so a melted harness/wires is most likely out of the question..
MrSo0h0o is offline   Reply With Quote
Old 02-04-2009, 04:20 PM   #4 (permalink)
The Connoisseur
CharmCityES's Avatar
check your fuses....maybe the aftermarket bulb blew out the fuse
its not uncommon for this to happen
The "Executive Sedan"
Old 02-04-2009, 04:54 PM   #5 (permalink)
icqboy51's Avatar
thanx u guys were dead on. blown fuse.
the owners manual suggest for headlight (low) 9006, 51W, type B
i see for replacement bulbs from Sylvania, their 9006 bulbs have 55W... would that lead to blown fuse/ headlights not working/ other problems?
thanx
Old 02-04-2009, 05:16 PM   #6 (permalink)
2007 Camry SE V6
You might want to try putting in a new fuse, then try the new 55w bulbs. If the fuse blows out again, don't use the new 55w and get a different kind. I would seriously doubt that a difference of 4 watts should cause the fuse to blow normally, but I am not an electrical expert.
Old 02-04-2009, 05:42 PM   #7 (permalink)
Twin & (1 of 8)
Luna2's Avatar
Gameroom cash: $393350
View Luna2's Photo Gallery
Gen6
Originally Posted by icqboy51 View Post
both the headlights were working prior.
i had a set of extra replacement 9006 bulbs, wanted to see if they are still working.
then i unplugged the OEM passenger-side ones in the car. (usual - twist and pull).
put in the replacement 9006 and the lights did not come on. so i thought the replacement one must be burnt out.
then i put back the OEM one and it did not come on (only driver-side OEM came on).... i did not touch the bulb's glass/ tip, hold on to the bulb on its base.
may be the OEM burnt out that fast (during this 3 minutes period?).
then to test if it is the passenger-side bulb that was burnt out or something else, i put the bulb to the driver-side and it worked!..... so it was not the bulb..
which is not good. if it was the bulb then it would be an easy replacement,
what might be causing this in this 3 min. period? is it the brown-ish connector (pictured below) that is causing this? wires (but i did not yank on the wires)? or something else? (hopefully nothing big!)...
thanx
Looks like you have a loose contact. the third photo looks like the contact on the left, is not as tight (close together) the one on the right. The fourth photo shows heat around the Red [I think] Green wire as it enters the socket.
2011 XLE, I4, AT, Sliver, New May 1, 2010
MFG 02/25/2010
Stock, Shucks!
"Kinda Hard to ID in a Parking Lot"
Luna2 is offline   Reply With Quote
Old 02-04-2009, 07:06 PM   #8 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
Should not be a problem going from 51W to 55W since they're the same bulb with different rating.
2007 Camry 2.4L 5M
