2az bell housing pattern - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-05-2009, 10:10 PM   #1 (permalink)
View singleslammer's Photo Gallery
Hi all. I have a 86 corolla sr5 and have been attempting to decide what would be the best engine to upgrade to. Basically here is what I have so far. The standard run of the mill motors and then the Tacoma 2.4/2.7L RZ series motors. These are great but heavy. Basically I was wondering if anyone knew what the bell housing pattern looked like on a 2az motor to see if there is anyway to turn it 90 degrees for my purposes. I have heard speculation that the 2az will mount to the 2/3rz bell housing without issue. However, no one has been able to confirm this am I don't have a 2az lying around I could check it against. If anyone as any ideas that would be great. Thanks, Jordan. Also, if you happen to know it is similar or the same as another engine that would be good to as I have come across a number of motors that share a bell housing with other motors.
singleslammer is offline   Reply With Quote
Old 02-06-2009, 01:42 AM   #2 (permalink)
Redline_Me's Avatar
Gameroom cash: $335135
View Redline_Me's Photo Gallery
You want front wheel drive? If i had the money that's the car i always wanted to work on or a 72 datsun s510 with a RX-7 engine. You should go with a 240sx motor if you have the money.
Redline_Me is offline   Reply With Quote
Old 02-06-2009, 10:42 AM   #3 (permalink)
self-proclaimed geenyus
jermyjerm's Avatar
View jermyjerm's Photo Gallery
have you researched the 2zz?much better engine to start with for performance.
jermyjerm is offline   Reply With Quote
Old 02-07-2009, 09:24 AM   #4 (permalink)
It lacks the torque of the 2az and there is no way to make it fit a rwd transmission.
No I don't want front wheel drive, the engine doesn't dictate fwd or rwd, the transmission does. A 240sx motor is heavier than the 2/3rz I mentioned above, with less hp and much less torque.
Old 02-08-2009, 01:38 AM   #5 (permalink)
Redline_Me's Avatar
When i was in H.S we put a V8 in a Geo metro lol. Twisted the frame first run.
Old 02-13-2009, 11:38 AM   #6 (permalink)
wow that was helpful. Any one have anything real to add?
Old 02-13-2009, 12:02 PM   #7 (permalink)
2010 Camry SE V6
BlackCamSe's Avatar
Gameroom cash: $400224
View BlackCamSe's Photo Gallery
how about a 2GR-FSE from the IS350. Or a 2JZ-GE from the Supra/IS300
Thanks netforcer for the awsome sig! You da man!
Seatbelt! you're piloting a vehicle were dual vvt-i hitts harder then VTEC and the torquesteer can possibly snap your wrists
BlackCamSe is online now   Reply With Quote
