How to change parkinglight bulbs? (I4 07 Camry) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-23-2009, 10:16 PM   #1 (permalink)
View BenzML's Photo Gallery
Anyone know how to change the front parkinglight bulbs, preferebly an easy DIY without having to remove the headlights?
BenzML is offline   Reply With Quote
Old 02-23-2009, 10:25 PM   #2 (permalink)
Here and there...
Gameroom cash: $153229
iTrader Score: 6 reviews
View lammydi's Photo Gallery
You don't have to remove your headlight.
For the left side bulb, turn your wheel to the right so you have more room to reach in a removed the plastic cover. Then reach your arm and hand all the way up to the parking bulb.
Old 02-23-2009, 10:28 PM   #3 (permalink)
Gameroom cash: $336835
View Redline_Me's Photo Gallery
Yep thats what i did, but i jacked the car up a little. It's a pain to change those bulbs but thats the easiest way and im gonna have to do it again soon.
Redline_Me is offline   Reply With Quote
Old 02-23-2009, 10:31 PM   #4 (permalink)
Which plastic cover? The Underbody cover (Same method for changing foglight bulbs) or the plastic cover above the tire? So will this methong work with the right side headlight?
Old 02-23-2009, 10:45 PM   #5 (permalink)
Here and there...
It's the plastic cover above the tire. This method will work with the right side also. (just turn your wheel to the left when you do the right side)
Old 02-23-2009, 11:29 PM   #6 (permalink)
The fender liner. There is a screw that holds a clip on the fender about 5 inches from the bottom and another one higher on the top remove those and pull out.
Old 02-25-2009, 10:14 AM   #7 (permalink)
I removed the screw but I cant seem to remove that clips, do I just pull on them to slide off?
Old 02-25-2009, 12:26 PM   #8 (permalink)
yeah just pull them to the side. They wont go easy but just keep prying them and they will come off.
Old 02-25-2009, 12:33 PM   #9 (permalink)
Joined the dark side. :D
Gameroom cash: $654791
View workerant's Photo Gallery
And broke one of the plastic clip.
workerant is online now   Reply With Quote
Old 02-25-2009, 12:39 PM   #10 (permalink)
^ mine came off no problem. the liner will stay on there even without the clip so it's no big deal.
Old 02-25-2009, 06:07 PM   #11 (permalink)
yeah i broke my plastic screw but it seems like its holding on fine
