So, here it is like promised.
*Disclaimer*
I take NO responsibility if something goes wrong on your car, as this is a guide to my “personal” swap. This is at your own risk.
List of parts needed:
1: Rear spindles (Caliper, Caliper Bracket, Parking brake components, knuckle)
2: Disc e-brake cables
Optional but recommended:
3: SS Brake Lines (I used Stop Tech, and they are great)
4: 4 new control arm bolts (Especially is in area with road salt)
*Drum hubs can be reused with disc setup
Tools Needed:
1: Socket Set
2: Breaker Bar
3: Torque Wrench
4: Jacks (2)
5: Jack Stands
6: Rubber Mallet
7: 10mm brake line wrench
8: Flat Head Screwdriver
9:
10:
Other Stuff needed:
1: Brake Fluid
2: PB Blaster
3: Brake Parts Cleaner
4:
5:
Remove everything, have fun, took me 2 days….Spray EVERYTHING with PB Blaster at least a day before, and spray several times until time for the work. Spray the hard line to soft line brake connection. Spray the rear of the backing plate around the knuckle.
1: Install the knuckle for the rear disc brakes.
2: Put some Antiseize around the outside like I did, in case you need to take out the hub again in the future. You’ll understand what I mean when you try to remove it……
3: Put the backing plate onto the hub. I’d recommend using the hubs you had on your car, as long as you know they are good. So it will be 1 less thing to worry about.
3a: Place the 4 hub bolts (circled in red) through the back of the backing plate, into the hub, for correct alignment. Using the rubber mallet, gently hammer the backing plate onto the hub.
4: Screw on the hub/backing plate to the knuckle.
5: Screw on the E-Brake cable to the backing plate.
5a: Attach the cable to the bracket on the e-brake assembly (Not together in my picture).
5b: Reasemble the rest of the E-brake components.
6: Plug in the ABS sensor plug (if equipped).
7: Put on Rotor and screw on the Caliper Bracket.
8: Screw on the Caliper.
9: Screw on the brake line (SS recommended).
10: BLEED THE BRAKES!!!!!!!!!!
* I have not connected the e-brake cables yet. 1 came in defective, so waiting on the other.
