how to turn off tire pressure light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-02-2009, 07:19 PM   #1 (permalink)
2007XLE
View 07camryxle13501's Photo Gallery
Angry how to turn off tire pressure light
Hello everyone, Im new here =] ......Dose anyone know how to reset the tire pressure light Or can you do that at all, I know all the tries are at the same psi even the spare and its still on. My senor was leaking air so i had to buy a new one from Toyota and i put it in. And they said to just drive the car and it till go off but its like a month later and its still on:headban g::headban g: ={ HELP ANYONE? I DRIVE A 2007 TOYOTA CAMRY XLE
07camryxle13501 is offline   Reply With Quote
Old 03-02-2009, 07:39 PM   #2 (permalink)
View camlex's Photo Gallery
do you have reset botton?
if answer is yes, then put the key in ignition ppush and hold reset botton turn key to power position and light will blink three time then release.
I have this pressure warning in my 99 sienna.
Hope that helps.
camlex is offline   Reply With Quote
Old 03-02-2009, 07:40 PM   #3 (permalink)
View GeorgiaHybrid's Photo Gallery
Read your manual, salvation lies within.....
Failing that, look in the glove box where your manual is for the reset button.
GeorgiaHybrid is offline   Reply With Quote
Old 03-02-2009, 08:40 PM   #4 (permalink)
2007XLE
[quote=camlex;2690771]do you have reset botton?
Hope that helps.[/quote
I dont know if it has it dose anyone know, if so can you tell me where, and i dont have a key for my car its a push start button
But Thanks for the help
Old 03-02-2009, 08:57 PM   #5 (permalink)
View Axxis8203's Photo Gallery
when you say you put in a new sensor.. do you mean that you purchased a new TPMS sensor from toyota, dismounted the tire from the wheel, installed the new sensor, then remounted the tire to the wheel?
if that's the case, then the reason the light is still on is because the TPMS does not recognize the newly installed sensors' serial number because it has not been programmed into the vehicles computer. this task can only be done by toyota and it is unlikely that they would have sold you a new sensor without informing you of this.
that said, the TPMS reset button is in the top left corner of the glove box. there is a procedure to resetting the system which is described in your manual.
Axxis8203 is offline   Reply With Quote
Old 03-02-2009, 09:08 PM   #6 (permalink)
-Kenny-
Guest
Posts: n/a
View -Kenny-'s Photo Gallery
its in yur glove box on the left side, where the red circle is
Old 03-02-2009, 09:22 PM   #7 (permalink)
2GR FTW
darksparkz's Avatar
View darksparkz's Photo Gallery
Or pull the cluster and remove the light for the sensor.
There might be a fuse also.
2007 Toyota Camry SE 2GR-FE
Retrofit TSX HID Projectors | TRD Lowering Springs | Smoked LED Tails | Custom Apexi WS2 Catback Exhaust | BlueBatMobile Eyelids| UR Front Strut Bar | UR 23mm Rear Sway Bar | K&N Short Ram Intake| Kenwood DNX8120 In-dash | Lexus IS350 18" Wheels | Toyota Japan JDM Vent Visors | IS-F Black Leather Shift Knob
Other cars: F20C (AP1) | 2JZ-GE (JCE10)
darksparkz is offline   Reply With Quote
Old 03-02-2009, 09:32 PM   #8 (permalink)
2007XLE
Thank you vary much .... now is there something you have to do like hold it for ten secs or what
